[MAPSERVER-USERS] Mapserver bug when generating a tiled map with
MapFish
Faldor
besse.pb at gmail.com
Mon Aug 4 11:27:08 EDT 2008
Hi all,
I use Mapserver with mapfish for the client side to display shapefiles which
I generated using ogr2ogr.
The problem is when I try to display a tiled layer (mapfish singleTile
property set to 'false'). Some tiles are generated by mapserver entirely
blank !
After a few researches I think it is due to the fact that those tiles are
extended "across" the -180°/+180° line.
For exemple, here is the imgext property from one of the calls to MapServer
which render a blank tile :
imgext=178.59375+-1.40625+271.40625+91.40625
Do you know of a way to fix this ?
Regards,
Pierre-Benoît
View this message in context: http://www.nabble.com/Mapserver-bug-when-generating-a-tiled-map-with-MapFish-tp18813432p18813432.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
