[mapserver-users] zoomRectangle in combination with zoomPoint
Peter Falk
peter at nexus.dk
Tue Aug 5 08:30:07 EDT 2008
I'm having some difficulties with zoomRectangle in combination with
zoomPoint, when working with both a map and a reference map.
The only way I've been able to successfully synchronize the map when
clicking on the reference map, is by using max_extent and an absolut
zoom-factor:
zoomPoint(
$this->zoom_factor, $this->clkpoint, $this->map->width,
$this->map->height,
$this->max_extent, $this->max_extent);
Thereby the zoom factor and the click point determine the extent of the
map.
But when using zoomRectangle it's not possible to do this. Instead one
must pass the actual extent as a parameter. When doing this, zoomPoint
no longer act correct.
Does anyone know how to overcome this problem?
Regards
Peter Falk
