[MAPSERVER-USERS] How to map attribute data (non-geom) from	Oracle(not Spatial)?
    Nolte, Tim
    Tim.Nolte at ipcswirelessinc.com
    Tue Aug  5 07:38:11 PDT 2008
Bill,
Here is a layer definition I am using for Oracle Spatial(Locator) data.
  LAYER
    GROUP "Cell Sites"
    NAME "On-Air"
    TYPE POINT
    STATUS ON
    CONNECTIONTYPE oraclespatial
    CONNECTION "username/password at sid"
    PROCESSING "CLOSE_CONNECTION=DEFER"
    DATA "geom FROM (SELECT st.bts_nbr, sgt.geom FROM site_tab st,
site_geom_tab sgt WHERE st.site_id = sgt.site_id AND st.site_status_id
IN (4,7)) USING SRID 8307"
    LABELITEM "bts_nbr"
    METADATA
      "static_legend" "1"
    END
    DUMP true
    CLASS
      NAME "On-Air Large Scale"
      MINSCALE 0
      MAXSCALE 1200000
      STYLE
        SYMBOL "circle"
        COLOR 22 129 17
        OUTLINECOLOR 255 255 255
        SIZE 12
      END
      LABEL
        TYPE TRUETYPE
        FONT "sans"
        SIZE 7
        POSITION CR
        OFFSET 0 2
        ANGLE AUTO
        BUFFER 3
        MINDISTANCE 30
        MINFEATURESIZE 10
        COLOR 0 0 0
        OUTLINECOLOR 245 245 231
        SHADOWSIZE 3 3
        BACKGROUNDSHADOWSIZE 1 -1
      END
    END
    CLASS
      NAME "On-Air Small Scale"
      MINSCALE 1200000
      MAXSCALE 6000000
      STYLE
        SYMBOL "circle"
        COLOR 22 129 17
        SIZE 8
      END
    END
  END
The key here is that you need to have MapServer compiled with Oracle
Spatial support. And you can see from my data line that that I do
standard Oracle SQL statements for building my spatial results. I'm not
using any shapefiles in this instance. The spatial data is actually
stored right in the database table. There are tools to import shapefiles
into Oracle. If your data is points you can build insert statements to
populated your geometry columns. You're probably going to want to do
some reading up on Oracle spatial.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Bill Wordsworth [mailto:bill.wordsworth at gmail.com]
> Sent: Tuesday, August 05, 2008 10:25 AM
> To: Nolte, Tim; mapserver-users at lists.osgeo.org
> Subject: Re: [MAPSERVER-USERS] How to map attribute data
> This is exciting news! I am using Oracle 10g and get Oracle Locator
> free but how do I map data from Oracle Locator? Are you doing a
> JOIN+FILTER? Can you share a LAYER snippet from your MAP file?
> Cheers, Bill
More information about the MapServer-users
