[mapserver-users] RE: Labeling
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Wed Aug 6 10:46:01 EDT 2008
That was it....moved the lines inside the LABEL CLASS....
Credit due to the GeoMoose Forum...(Dan)
But I do thank you all for your help...it is very appreciated.
Especially for Green coders like myself...
Thanks again Steve for your response
CLASS
LABEL
PUT LINES HERE
END
END
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Wednesday, August 06, 2008 9:42 AM
To: Jay Kapalczynski; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] RE: Labeling
>From your example I can see that your "ANGLE" parameter is in the wrong
object it should be in the label object
to rotate the text. As is you should be throwing parsing errors. the
item storing the angle need not be numeric although the values must
represent numbers upon conversion.
Steve
>>> Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us> 08/06/08 2:15
AM >>>
What I am trying to do is use annotation from a Geodatabase. From what
I hear GeoMoose / Map Server will not read it.
I converted the Annotation Feature Class to a Point.
Then created a Polygon from the Annotation Feature Classes, pointing to
the Point Feature class for the Attributes (label field, degree field)
I then read the Polygons into GeoMoose and label on the field and Angle
the text by "Angle' Field.
The ANGLE call to Map Server dosent seem to work in this case
Any thoughts?
Sent: Tuesday, August 05, 2008 2:48 PM
To: 'mapserver-users at lists.osgeo.org'
Subject: Labeling
Don't know if I have to correct location.
I have been successful labeling street centerlines using the ANGLE
FOLLOW in the .map File
This is being performed on a Shapefile Line feature
I also have a Polygon Feature that has a field that I am trying to
label....once again I need the text to follow the polygon
As you can see from the image the road names a following properly, but
the labels for the polygons are not following...
I tried the ANGLE FOLLOW on the Polygon and It will not draw..
I tried ANGLE [Angle] with Angle being a field name that holds Degree
values (ex 270) does the field have to be numeric?
Is there some other syntax that I have to put in the map file that will
force the text to follow the Polygon?
THANKS
STREET MAP FILE
LAYER # Maple Grove Streets Name
NAME Streets_Labels
DATA './GEOCODED_CENTERLINES2.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 6000
MINSCALE 100
LABELITEM 'STREET_NAM'
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 10
SIZE 8
MINSIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 192
BUFFER 2
END
END
END # Maple Grove Streets Name
PARCELS MAP FILE THAT DOES NOT WORK
LAYER # Maple Grove Parcels
NAME Parcel_Labels
DATA './parcels.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 2500
MINSCALE 100
LABELITEM 'TextString'
ANGLE [Angle]
POSITION AUTO
PARTIALS FALSE
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
MAXSIZE 8
SIZE 8
MINSIZE 2
#ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 128
BUFFER 2
END
END
END # Maple Grove Parcels
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080806/888899c1/attachment-0001.html
