[mapserver-users] msDrawRaster(): Image handling error with sles
/opensuse
Frank Warmerdam
warmerdam at pobox.com
Wed Aug 6 11:35:08 EDT 2008
John,
My suggestion would be to carefully review the paths you are using,
and the permissions of the server. You may find it helpful to test
from the commandline to isolate cgi permissions issues, and so that you
can see immediate debugging information.
Best regards,
John Westwood wrote:
> Okay,
> I did a mapserv -v at the command line and it returned the following supported inputs:
> INPUT=TIFF INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Typing gdalinfo --formats at the command line returns:
> GTiff (rw+): GeoTIFF
> amongst many other supported formats.
> So it should work, but it doesn't. Any ideas?
> Thanks
> John W.
>>>> On 06/08/2008 at 12:57, in message <48999FD6.FEDC.0053.0 at port.ac.uk>, "John
> Westwood" <John.Westwood at port.ac.uk> wrote:
>> Hi,
>> I have successfully compiled MapServer 5.2 on both Debian Etch and SUSE =
>> Linux Enterprise Server (SLES) 10 SP2 . Everything works fine on Debian, =
>> but on SUSE I receive the following error when trying to display any =
>> raster based layers:
>> msDrawMap(): Image handling error. Failed to draw layer named '......'.; =
>> msDrawRaster(): Image handling error. Unrecognized or unsupported image =
>> format; drawEPP(): Image handling error. EPPL7 support is not available.
>> I realise that the EPPL7 reference in the error message is a red herring. =
>> My raster layers are in geotiff format and the output format is png. =
>> Vector layers render fine as pngs. I am using MapServer as a WMS server. I =
>> compiled with agg, gd and gdal. I don't understand why it's not working! =
>> Please help!
>> Many thanks,
>> John W.
>> Great Britain Historical GIS Project.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
and watch the world go round - Rush | President OSGeo, http://osgeo.org
