[mapserver-users] About labeling
Carlos Ruiz
boolean10001 at yahoo.com
Wed Aug 6 14:53:55 EDT 2008
I have a layer wich contains the street names, and i want to display it. Then, system crashes
saying that CGI / FastCGI detected a problem and it must close.
The error signature throws this:
szAppName : php-cgi.exe szAppVer : 5.2.5.5 szModName : libmap.dll
szModVer : 0.0.0.0 offset : 0002fded
So, i was wondering why ... and then, i noticed this:
I'm showing an embeded scalebar, so i need to call the drawLabelCache method to render
it.
$img = $map->draw();
$map->embedScalebar($img);
$map->drawLabelCache($img);
Then, my street names layer looks like this:
LAYER
NAME "streetnames"
CONNECTION "..."
CONNECTIONTYPE POSTGIS
DATA "the_geom from streetnames"
STATUS OFF
TYPE POINT
TRANSPARENCY 100
LABELITEM "textstring"
CLASS
LABEL
FONT "arial"
TYPE TRUETYPE
COLOR 255 128 0
OUTLINECOLOR 255 255 255
SIZE 5
ANGLE [text_angle]
PARTIALS FALSE
END
END
MINSCALE 0
MAXSCALE 10000
END
Then I added within the LAYER section the tag LABELCACHE OFF, and it works just fine.
Without seeing source code I figure that maybe the LabelCache pointers are to few, isn't ?
Or someone know what else could be happening ?
IC Carlos Ruiz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080806/b2734152/attachment.html
