[MAPSERVER-USERS] How to map attribute data (non-geom)
fromOracle(not Spatial)?
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Wed Aug 6 15:20:23 EDT 2008
Bill,
You got it.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Bill Wordsworth
> Sent: Wednesday, August 06, 2008 2:47 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [MAPSERVER-USERS] How to map attribute data
> (non-geom) fromOracle(not Spatial)?
> http://www.oracle.com/technology/products/spatial/spatial_loca
> tor_features.html
> Shapefile Converter > SQL*Loader > MapServer Query? Is that
> all it takes?
> On Tue, Aug 5, 2008 at 4:01 PM, Bill Wordsworth
> <bill.wordsworth at gmail.com> wrote:
> > Tim,
> > I didn't know you could do "geom from..." without Oracle Spatial, so
> > this is great!
> > This is my current compilation:
> > MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP
> > OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS
> SUPPORTS=GEOS
> > INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > DEBUG=MSDEBUG
> > I don't see any Oracle support. Could you shed some light on how to
> > enable that? And how do you insert geom into Oracle Locator without
> > Oracle Spatial- what tools?
> > So as I understand, Oracle Spatial allows geoprocessing type queries
> > (buffer, nearest, shortest) while Oracle Locator doesn't allow any
> > thing that but does display geom (point, line, polygon, (raster)).
> > Correct?? I just want to take a shapefile, insert it and
> then display
> > its filtered set.
> > Cheers, Bill
> > On Tue, Aug 5, 2008 at 10:38 AM, Nolte, Tim
> > <Tim.Nolte at ipcswirelessinc.com> wrote:
> >> Bill,
> >> Here is a layer definition I am using for Oracle
> Spatial(Locator) data.
> >> LAYER
> >> GROUP "Cell Sites"
> >> NAME "On-Air"
> >> TYPE POINT
> >> STATUS ON
> >> CONNECTIONTYPE oraclespatial
> >> CONNECTION "username/password at sid"
> >> PROCESSING "CLOSE_CONNECTION=DEFER"
> >> DATA "geom FROM (SELECT st.bts_nbr, sgt.geom FROM site_tab st,
> >> site_geom_tab sgt WHERE st.site_id = sgt.site_id AND
> st.site_status_id
> >> IN (4,7)) USING SRID 8307"
> >> LABELITEM "bts_nbr"
> >> METADATA
> >> "static_legend" "1"
> >> END
> >> DUMP true
> >> CLASS
> >> NAME "On-Air Large Scale"
> >> MINSCALE 0
> >> MAXSCALE 1200000
> >> STYLE
> >> SYMBOL "circle"
> >> COLOR 22 129 17
> >> OUTLINECOLOR 255 255 255
> >> SIZE 12
> >> END
> >> LABEL
> >> TYPE TRUETYPE
> >> FONT "sans"
> >> SIZE 7
> >> POSITION CR
> >> OFFSET 0 2
> >> ANGLE AUTO
> >> BUFFER 3
> >> MINDISTANCE 30
> >> MINFEATURESIZE 10
> >> COLOR 0 0 0
> >> OUTLINECOLOR 245 245 231
> >> SHADOWSIZE 3 3
> >> BACKGROUNDSHADOWSIZE 1 -1
> >> END
> >> END
> >> CLASS
> >> NAME "On-Air Small Scale"
> >> MINSCALE 1200000
> >> MAXSCALE 6000000
> >> STYLE
> >> SYMBOL "circle"
> >> COLOR 22 129 17
> >> SIZE 8
> >> END
> >> END
> >> END
> >> The key here is that you need to have MapServer compiled
> with Oracle
> >> Spatial support. And you can see from my data line that that I do
> >> standard Oracle SQL statements for building my spatial
> results. I'm not
> >> using any shapefiles in this instance. The spatial data is actually
> >> stored right in the database table. There are tools to
> import shapefiles
> >> into Oracle. If your data is points you can build insert
> statements to
> >> populated your geometry columns. You're probably going to
> want to do
> >> some reading up on Oracle spatial.
> >> - Tim
> >> iPCS Wireless, Inc.
> >> Kentwood, MI 49512
> >> PCS: 616-706-2438
> >> Fax: 616-554-6484
> >>> From: Bill Wordsworth [mailto:bill.wordsworth at gmail.com]
> >>> Sent: Tuesday, August 05, 2008 10:25 AM
> >>> To: Nolte, Tim; mapserver-users at lists.osgeo.org
> >>> (non-geom) from Oracle(not Spatial)?
> >>> This is exciting news! I am using Oracle 10g and get
> Oracle Locator
> >>> free but how do I map data from Oracle Locator? Are you doing a
> >>> JOIN+FILTER? Can you share a LAYER snippet from your MAP file?
> >>> Cheers, Bill
