[mapserver-users] Horizontal line appears at the edge with circle
symbol
Ei Fujioka
efujioka at duke.edu
Wed Aug 6 17:23:01 EDT 2008
Dear experts,
I'm upgrading Mapserver from 4.2 to 5.2 and experiencing a very annoying
problem.
There appears a horizontal line at the edge of the map drawn by
Mapserver 5.2 when the symbol is set to "circle". This didn't happen
with Mapserver 4.2.
When I change the symbol to "square", the line doesn't appear.
I've tried various settings (e.g. SIZE, ANGLE, ANTIALIAS etc.) with no luck.
Does anyone have any idea what's wrong with it?
** Examples: **
Mapserver 5.2 with circle symbol:
http://seamap-dev.env.duke.edu/seamap2/main/seamap2_gm.php?sid=horizontal_line_with_circle&mode=draw_map&outputformat=PNG24&layer_name=dist_sp_01deg&layer_type=point&mapsize=256%2B256&mapext=-90%2C27.059125784374068%2C-84.375%2C31.95216223802497
Mapserver 5.2 with square symbol:
http://seamap-dev.env.duke.edu/seamap2/main/seamap2_gm.php?sid=no_line_with_square&mode=draw_map&outputformat=PNG24&layer_name=dist_sp_01deg&layer_type=point&mapsize=256%2B256&mapext=-90%2C27.059125784374068%2C-84.375%2C31.95216223802497
** Mapserver info. **
./mapserv -v
MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
** Mapfile exerpt **
MAP
EXTENT -20001364 -15000982 20001253 15000982
IMAGECOLOR 255 255 255
IMAGETYPE gif
SYMBOLSET "/var/www/seamap2/map/symbolset.map"
SHAPEPATH "/data/shapefiles/"
SIZE 256 256
STATUS ON
TRANSPARENT TRUE
UNITS DD
NAME "SEAMAP ONLINE MAPPER"
PROJECTION
"init=epsg:54004"
END
LAYER
CLASSITEM "_sp_tsn"
CONNECTION "host=***"
CONNECTIONTYPE POSTGIS
DATA "_geom from (***) ***"
NAME "zd_35"
PROJECTION
"init=epsg:4326"
END
STATUS ON
TOLERANCE 0.1
TYPE POINT
CLASS
NAME "Anatidae"
EXPRESSION "174983"
STYLE
ANGLE 360
COLOR 255 255 0
OPACITY 50
OUTLINECOLOR 0 0 0
SIZE 9
SYMBOL "circle" : annoying horizontal line appears
#SYMBOL "square" : when square is used, no horizontal line
END
TITLE "174983"
END
Ei Fujioka
Research Associate
Duke University
(919) 613-8021
