[mapserver-users] Horizontal line appears at the edge with circle
symbol
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 6 18:50:08 EDT 2008
This is a know bug. I think it is:
http://trac.osgeo.org/mapserver/ticket/1719
-Steve W
Ei Fujioka wrote:
> Dear experts,
> I'm upgrading Mapserver from 4.2 to 5.2 and experiencing a very annoying
> problem.
> There appears a horizontal line at the edge of the map drawn by
> Mapserver 5.2 when the symbol is set to "circle". This didn't happen
> with Mapserver 4.2.
> When I change the symbol to "square", the line doesn't appear.
> I've tried various settings (e.g. SIZE, ANGLE, ANTIALIAS etc.) with no
> luck.
> Does anyone have any idea what's wrong with it?
> ** Examples: **
> Mapserver 5.2 with circle symbol:
> http://seamap-dev.env.duke.edu/seamap2/main/seamap2_gm.php?sid=horizontal_line_with_circle&mode=draw_map&outputformat=PNG24&layer_name=dist_sp_01deg&layer_type=point&mapsize=256%2B256&mapext=-90%2C27.059125784374068%2C-84.375%2C31.95216223802497
> Mapserver 5.2 with square symbol:
> http://seamap-dev.env.duke.edu/seamap2/main/seamap2_gm.php?sid=no_line_with_square&mode=draw_map&outputformat=PNG24&layer_name=dist_sp_01deg&layer_type=point&mapsize=256%2B256&mapext=-90%2C27.059125784374068%2C-84.375%2C31.95216223802497
> ** Mapserver info. **
> ./mapserv -v
> MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> ** Mapfile exerpt **
> MAP
> EXTENT -20001364 -15000982 20001253 15000982
> IMAGECOLOR 255 255 255
> IMAGETYPE gif
> SYMBOLSET "/var/www/seamap2/map/symbolset.map"
> SHAPEPATH "/data/shapefiles/"
> SIZE 256 256
> STATUS ON
> TRANSPARENT TRUE
> UNITS DD
> NAME "SEAMAP ONLINE MAPPER"
> PROJECTION
> "init=epsg:54004"
> END
> LAYER
> CLASSITEM "_sp_tsn"
> CONNECTION "host=***"
> CONNECTIONTYPE POSTGIS
> DATA "_geom from (***) ***"
> NAME "zd_35"
> PROJECTION
> "init=epsg:4326"
> END
> STATUS ON
> TOLERANCE 0.1
> TYPE POINT
> CLASS
> NAME "Anatidae"
> EXPRESSION "174983"
> STYLE
> ANGLE 360
> COLOR 255 255 0
> OPACITY 50
> OUTLINECOLOR 0 0 0
> SIZE 9
> SYMBOL "circle" : annoying horizontal line appears
> #SYMBOL "square" : when square is used, no horizontal line
> END
> TITLE "174983"
> END
