[mapserver-users] GPS to GIS
Benoît Andrieu
bea at ixsea.com
Thu Aug 7 03:40:00 EDT 2008
Hi Peter,
What do you mean with 'GIS' coordinates ?
For me, GIS means Geographic Information System and is a very common term.
Looking at your 'GIS' coordinates I would say that your GIS coordinate
system is a UTM 32 coordinate system.
And in your case, you could use cs2cs
(http://proj.maptools.org/man_cs2cs.html) in order to make the translation.
cs2cs.exe +proj=latlong +datum=WGS84 +to +proj=utm +zone=32 +datum=WGS84 -r
input : 54.9808N 8.86707E
output : 491492.61 6092662.95 0.00
The results are not exactly accurate with yours but they are close enough to
me (by what ? 600 meters ? ^^).
I hope it will help.
Regards,
Benoît Andrieu
----- Original Message -----
To: <mapserver-users at lists.osgeo.org>
Sent: Thursday, August 07, 2008 9:20 AM
Subject: [mapserver-users] GPS to GIS
> Hi David,
> Yes I know i was a bit vague. What I need is a simple function, that can
> turn a point in GPS - a lattitude and a logitude value - into a point in
> GIS.
> I.e. I got these coordinate:
> GPS: N: 54.9809 E: 8.86707
> that applies to
> GIS: X: 491055.41 Y: 6092507.928
> What I need is the correlation between the two.
> Regards
> Peter
