[mapserver-users] Horizontal line appears at the edge with circle
symbol
Ei Fujioka
efujioka at duke.edu
Fri Aug 8 19:02:06 EDT 2008
Thanks, Steve, for the quickest response.
I managed to upgrade the GD library and recompile PHP, Mapserver and the
problem is gone.
GD: 2.0.35 (previously 2.0.33 from yum)
PHP: 5.2.6 (previously 5.1.6 from yum)
Mapserver: 5.2
Ei
Stephen Woodbridge wrote:
> This is a know bug. I think it is:
> http://trac.osgeo.org/mapserver/ticket/1719
> -Steve W
> Ei Fujioka wrote:
>> Dear experts,
>> I'm upgrading Mapserver from 4.2 to 5.2 and experiencing a very
>> annoying problem.
>> There appears a horizontal line at the edge of the map drawn by
>> Mapserver 5.2 when the symbol is set to "circle". This didn't happen
>> with Mapserver 4.2.
>> When I change the symbol to "square", the line doesn't appear.
>> I've tried various settings (e.g. SIZE, ANGLE, ANTIALIAS etc.) with no
>> luck.
>> Does anyone have any idea what's wrong with it?
>> ** Examples: **
>> Mapserver 5.2 with circle symbol:
>> http://seamap-dev.env.duke.edu/seamap2/main/seamap2_gm.php?sid=horizontal_line_with_circle&mode=draw_map&outputformat=PNG24&layer_name=dist_sp_01deg&layer_type=point&mapsize=256%2B256&mapext=-90%2C27.059125784374068%2C-84.375%2C31.95216223802497
>> Mapserver 5.2 with square symbol:
>> http://seamap-dev.env.duke.edu/seamap2/main/seamap2_gm.php?sid=no_line_with_square&mode=draw_map&outputformat=PNG24&layer_name=dist_sp_01deg&layer_type=point&mapsize=256%2B256&mapext=-90%2C27.059125784374068%2C-84.375%2C31.95216223802497
>> ** Mapserver info. **
>> ./mapserv -v
>> MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS INPUT=EPPL7
>> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> ** Mapfile exerpt **
>> MAP
>> EXTENT -20001364 -15000982 20001253 15000982
>> IMAGECOLOR 255 255 255
>> IMAGETYPE gif
>> SYMBOLSET "/var/www/seamap2/map/symbolset.map"
>> SHAPEPATH "/data/shapefiles/"
>> SIZE 256 256
>> STATUS ON
>> TRANSPARENT TRUE
>> UNITS DD
>> NAME "SEAMAP ONLINE MAPPER"
>> PROJECTION
>> "init=epsg:54004"
>> END
>> LAYER
>> CLASSITEM "_sp_tsn"
>> CONNECTION "host=***"
>> CONNECTIONTYPE POSTGIS
>> DATA "_geom from (***) ***"
>> NAME "zd_35"
>> PROJECTION
>> "init=epsg:4326"
>> END
>> STATUS ON
>> TOLERANCE 0.1
>> TYPE POINT
>> CLASS
>> NAME "Anatidae"
>> EXPRESSION "174983"
>> STYLE
>> ANGLE 360
>> COLOR 255 255 0
>> OPACITY 50
>> OUTLINECOLOR 0 0 0
>> SIZE 9
>> SYMBOL "circle" : annoying horizontal line appears
>> #SYMBOL "square" : when square is used, no horizontal line
>> END
>> TITLE "174983"
>> END
Ei Fujioka
Research Associate
Duke University
(919) 613-8021
