[mapserver-users] ShpTree
Gregor Mosheh
gregor at hostgis.com
Mon Aug 11 16:35:41 EDT 2008
Jay Kapalczynski wrote:
> I am trying to figure out what I need to do/install/run to create a .qix
> file (tile index) for a few of my shapefiles.
> I have looked this up on a few pages and still am confused.
Example:
shptree streets.shp
That will create streets.qix
Note that for Mapserver (rather, OGR) to USE the qix file, you must not
specify the .shp extension in your DATA statement. If you do, the qix
will simply be skipped. e.g.
DATA "data/streets/streets.shp"
should be:
DATA "data/streets/streets"
(someone correct me if this has changed)
Gregor Mosheh / Greg Allensworth, BS, A+
System Administrator
HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
