[mapserver-users] ShpTree
Fischer, Brian
bfischer at houstonengineeringinc.com
Mon Aug 11 17:18:36 EDT 2008
Jay,
With the MS4W package it is included in the C:\ms4w\tools\mapserv
folder. You just need to make sure you run the setenv.bat first before
you run shptree command. There is documentation in the MS4W readme
files that explain it further. That is what I use all the time.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Gregor
Mosheh
Sent: Monday, August 11, 2008 3:36 PM
To: Jay Kapalczynski
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] ShpTree
Jay Kapalczynski wrote:
> I am trying to figure out what I need to do/install/run to create a
> .qix file (tile index) for a few of my shapefiles.
> I have looked this up on a few pages and still am confused.
Example:
shptree streets.shp
That will create streets.qix
Note that for Mapserver (rather, OGR) to USE the qix file, you must not
specify the .shp extension in your DATA statement. If you do, the qix
will simply be skipped. e.g.
DATA "data/streets/streets.shp"
should be:
DATA "data/streets/streets"
(someone correct me if this has changed)
Gregor Mosheh / Greg Allensworth, BS, A+ System Administrator HostGIS
cartographic development & hosting services http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
