[mapserver-users] Tiled image handling error
George A. Dubin
lysholm at tut.by
Wed Aug 13 03:12:59 EDT 2008
On Wed, 13 Aug 2008 09:54:19 +0300, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi> wrote:
TYPE RASTER - ofcourse, this helped! Thanks a lot!!!! I feel myself really
stupid now =)) ...
> Hi,
> A few suggestions:
>> TYPE LINE
> Should probably be TYPE RASTER
>> STATUS OFF
> STATUS DEFAULT or STATUS ON might be better alternatives
> If those changes will not help and you only have one tiff file to be
> displayed on layer "navi" then you can simplify map file a bit by
> leaving out TILEINDEX and TILEITEM and pointing directly to your image
> by using
> DATA "/var/www/map/shapes/navi.shp"
> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
>> George A. Dubin
>> Lähetetty: 13. elokuuta 2008 9:38
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: [mapserver-users] Tiled image handling error
>> Hi all! I'm having a problem with tiled tiff when mapserver
>> is working as WMS. While trying to display "navi" layer is
>> produces an error:
>> msDrawMap(): Image handling error. Failed to draw layer named navi;.
>> msSHPOpenFile(): Unable to access file. (/var/www/map/shapes/navi.tif)
>> But the tiff exists there and owned by Apache user... What am
>> I doing wrong?
>> Layer section in my mapfile:
>> LAYER
>> NAME navi
>> TYPE LINE
>> TILEINDEX "/var/www/map/shapes/navi.shp"
>> TILEITEM "LOCATION"
>> STATUS OFF
>> METADATA
>> wms_title "navi"
>> wms_abstract "navigation map"
>> wms_srs "EPSG:32235"
>> END
>> CLASS
>> NAME "Navi"
>> END
>> END
>> Other layers are working - 2 rasters and one postgis layer
>> with points.
>> Отправлено M2, революционной почтовой программой Opera:
>> http://www.opera.com/mail/
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
