[mapserver-users] Re WFS server error. Incomplete WFS
request:SERVICE parameter missing
Daniel Morissette
dmorissette at mapgears.com
Thu Aug 14 10:00:31 EDT 2008
I have created a ticket for this issue and will try to look into it today:
http://trac.osgeo.org/mapserver/ticket/2737
BTW, I don't think this is directly related to ticket #2351... the fix
for 2531 might fix this as well, but this issue may have been introduced
by some changes to the WFS support in MapServer 5.2.0.
Daniel
bartvde at osgis.nl wrote:
> Hi Derek,
> I think the appropriate ticket to watch is:
> http://trac.osgeo.org/mapserver/ticket/2531
> you can add yourself to the cc if you have an OSGEO Trac account.
> Best regards,
> Bart
>> Thanks Bart
>> That works within a URL in a browser, all I have to do is to modify the
>> source code for world wind and add a temp fix until a patch is issued for
>> Mapserver. How do I know when Mapserver has been updated?
>> Again many thanks
>> Derek
>> ----- Original Message ----
>> From: "bartvde at osgis.nl" <bartvde at osgis.nl>
>> To: Derek Bain <beartreeyoga at yahoo.co.uk>
>> Cc: mapserver-users at lists.osgeo.org
>> Sent: Thursday, 14 August, 2008 11:01:43
>> Subject: Re: [mapserver-users] Re WFS server error. Incomplete WFS
>> Hi Derek,
>> I can confirm this is a bug. Maybe Tom Kralidis or Daniel could comment on
>> this more?
>> The only way around it now is to add service=WMS to your request, but as
>> you indicate the OGC spec only requires this for GetCapabilities.
>> Best regards,
>> Bart
>>> Hi
>>> I tried removing the ampesand as suggested by Jukka but that made no
>>> difference. I downloaded an http debugger tool and checked the getmap
>>> request, here it is split up over a number of lines for readability. I
>>> checked with the WMS 1.1.1 spec and it complies with GetMap. It does not
>>> require a SERVICE parameter and WFS is not specified. I also tried the
>>> GET
>>> in a web browser and got the same error.
>>> Could one of the developers confirm that the GET conforms to what
>>> mapserver requires for v1.1.1
>>> I need someone to give me some advice as I seem to be going around in
>>> circles and not getting anywhere i.e. I can't see the wood for the trees
>>> many many many thanks in advance
>>> Derek
>>> PS My map file is in my initial post if anyone wants to check it out
>>> GET /cgi-bin/mapserv.exe?
>>> request=GetMap&
>>> layers=DEPCNT&
>>> TRANSPARENT=TRUE&
>>> BGCOLOR=0xFF00FF&
>>> map=d:/MyTestData/Shapes.map&
>>> srs=EPSG:4326&
>>> width=512&
>>> height=512&
>>> bbox=-81.5625,25.3125,-78.75,28.125&
>>> format=image/png&
>>> version=1.1.1&
>>> styles= HTTP/1.1
>>> User-Agent: World Wind v1.4.0.0 (Microsoft Windows NT 5.1.2600 Service
>>> Pack 3, en-GB)
>>> Host: localhost:8082
>>> Connection: Keep-Alive
>>> HTTP/1.1 200 OK
>>> Date: Thu, 14 Aug 2008 08:47:24 GMT
>>> Server: Apache/2.2.9 (Win32)
>>> Keep-Alive: timeout=5, max=100
>>> Transfer-Encoding: chunked
>>> Content-Type: text/xml
>>> <?xml version="1.0" encoding="ISO-8859-1"?>
>>> <ows:ExceptionReport
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:ows="http://www.opengis.net/ows/1.1" version="1.1.1"
>>> xml:lang="en-US" xsi:schemaLocation="http://www.opengis.net/ows/1.1
>>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd">
>>> <ows:Exception exceptionCode="service"
>>> locator="MissingParameterValue">
>>> <ows:ExceptionText>msWFSDispatch(): WFS server error. Incomplete WFS
>>> request: SERVICE parameter missing</ows:ExceptionText>
>>> </ows:Exception>
>>> </ows:ExceptionReport>
>>> GET
>>> /cgi-bin/mapserv.exe?request=GetMap&layers=DEPCNT&TRANSPARENT=TRUE&BGCOLOR=0xFF00FF&map=d:/SeeTrack_Missions/MyTestData/Shapes.map&srs=EPSG:4326&width=512&height=512&bbox=-84.375,25.3125,-81.5625,28.125&format=image/png&version=1.1.1&styles=
>>> HTTP/1.1
>>> Pack 3, en-GB)
>>> HTTP/1.1 200 OK
>>> Content-Length: 552
>>> </ows:Exception>
>>> Send instant messages to your online friends
>>> http://uk.messenger.yahoo.com
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Send instant messages to your online friends http://uk.messenger.yahoo.com
Daniel Morissette
http://www.mapgears.com/
