[MAPSERVER-USERS] how to avoid overlapping points
daa32 darenas2001 at yahoo.es
Fri Aug 15 13:38:19 PDT 2008
Hi Steve,
I´m using a point shape. Here you can see part of my map file:
LAYER
 NAME 'prueba'
 DATA 'G:\shapes\prueba'
 TYPE POINT
 STATUS on
 MAXSCALEDENOM 500000
 OPACITY ALPHA
 TOLERANCE 4
 DUMP TRUE
 DEBUG OFF
 PROCESSING "CLOSE_CONNECTION=DEFER"
SYMBOLSCALEDENOM 1000000
  CLASSITEM 'CENTRO'
  CLASS
  NAME 'Aeropuertos'
  EXPRESSION ('[CENTRO]' = '5')
  STYLE
   COLOR 0 0 0
   SYMBOL 'aeropuertos'
   SIZE 10
   #MINSIZE 1
   MAXSIZE 14
  END #STYLE
 END #CLASS
CLASS
  NAME 'helipuertos'
  EXPRESSION ('[CENTRO]' = '2')
  STYLE
   COLOR 0 0 0
   SYMBOL 'helipuertos'
   SIZE 10
   #MINSIZE 1
   MAXSIZE 14
  END #STYLE
 END #CLASS
then, I understood from your advice I have to use "TYPE ANNOTATION" , better
than "TYPE POINT" to avoid overlapping , haven´t I?
I´ve attached a screen capture where you can check my problem
http://www.nabble.com/file/p19004959/prueba.jpg
Thanks again
Steve Lime wrote:
> What are you after instead? If you use an annotation layer a marker is
> considered part of the
> label and is used in collision avoidance.
> Steve
>>>> On 8/15/2008 at 11:11 AM, in message
> <19000618.post at talk.nabble.com>, daa32
> <darenas2001 at yahoo.es> wrote:
>> Hi folks!
>> I´m making a WMS using a point layer. The questions is that those
> points are
>> very close each other and get overlapping. Do anyone know how to
> avoid that
>> problem?
>> thanks a million
>> David Arenas (Spain)
>> View this message in context:
> http://www.nabble.com/how-to-avoid-overlapping-points-tp19000618p19000618.htm
>> l
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://www.nabble.com/how-to-avoid-overlapping-points-tp19000618p19004959.html
More information about the MapServer-users mailing list
