[mapserver-users] How to display vector symbols (direction
andmagnitude) in MapServer?
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Aug 18 13:38:59 EDT 2008
Just in terms of the image...
Steve
>>> On 8/18/2008 at 6:30 AM, in message <48A95D5F.2070606 at nsidc.org>, John Maurer
<maurerj at nsidc.org> wrote:
> Thanks for the suggestion, Daniel! I was unaware of the ANGLE parameter
> in MapServer 5.0. One remaining concern I have, though, is how the angle
> will be interpreted by MapServer? Will -90 degrees always point to the
> South Pole regardless of the map projection I'm using (e.g. a polar
> stereo map centered on the South Pole), or will it always just point to
> the bottom of the map image regardless of the projection? i.e. Does
> MapServer interpret the degrees spatially or just in terms of the image?
> Unfortunately, if the latter is the case (which I suspect it probably
> is) it will not solve my problem. Do you know? Thanks again!
> Cheers,
> John Maurer
> Daniel Morissette wrote:
>> John Maurer wrote:
>>> Dear MapServer Users,
>>> Does anybody have experience displaying vectors in MapServer? By
>>> "vectors", I don't mean the usual vector vs. raster difference. What
>>> I mean is displaying data like wind vectors, which are point
>>> locations that have both a direction (degrees) and magnitude (e.g.
>>> meters per second). Usually these are displayed as arrows, which each
>>> point in a certain direction and whose tails vary in length depending
>>> on the magnitude each measurement. Is this possible in MapServer?
>>> Thanks for any suggestions!
>> You could bind the symbol size and angle to an attribute in your layer
>> definition.
>> If you can precompute the size in pixels based on the wind speed and
>> store that to an 'arrowsize' attribute then you could use a layer
>> defn's like this:
>> LAYER
>> TYPE POINT
>> CLASS
>> SYMBOL 'arrow'
>> ANGLE [direction]
>> SIZE [arrowsize]
>> COLOR 0 0 0
>> END
>> END
>> If you can't precompute the arrow size in pixels, then you could use
>> classes based on the wind speed attribute:
>> LAYER
>> TYPE POINT
>> CLASSITEM 'windspeed'
>> CLASS
>> EXPRESSION ([windspeed] < 5)
>> SYMBOL 'arrow'
>> ANGLE [direction]
>> SIZE 10
>> COLOR 0 0 0
>> END
>> CLASS
>> EXPRESSION ([windspeed] < 25)
>> SYMBOL 'arrow'
>> ANGLE [direction]
>> SIZE 15
>> COLOR 0 0 0
>> END
>> CLASS
>> EXPRESSION ([windspeed] < 100)
>> SYMBOL 'arrow'
>> ANGLE [direction]
>> SIZE 20
>> COLOR 0 0 0
>> END
>> CLASS
>> # No expression ... catch all for windspeed > 100
>> SYMBOL 'arrow'
>> ANGLE [direction]
>> SIZE 25
>> COLOR 0 0 0
>> END
>> END
>> Daniel
