[mapserver-users] build mapserver 5.2.0 with proj 4.6.0
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Tue Aug 19 05:31:36 EDT 2008
make sure you don't have any pre-installed Proj lib which would get
linked during the ./configure
Jacolin Yves a écrit :
> Hello,
> I am trying to build mapserver 5.2.0 with proj-4.6.0. The ./configure script
> tells me : "configure: error: This version of PROJ is too old. PROJ4.4.2 or
> later is required." , here is the configure comande line:
> ./configure
> --with-postgis
> --with-wmsclient --with-wfsclient
> --with-geos
> --with-proj=/usr/local/
> --with-gdal --with-ogr
> --with-freetype=/usr/bin/freetype-config --with-eppl --with-xpm=/usr/X11R6/lib/
> --with-gd=/usr/ --with-agg=/mnt/data/compil/agg-2.5/
> --with-curl-config=/usr/bin/curl-config
> --with-tiff --with-xml2-config=/usr/bin/xml2-config
> Do you know how to resolv this?
> Thanks
> Y.
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
