[mapserver-users] build mapserver 5.2.0 with proj 4.6.0
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Tue Aug 19 05:44:00 EDT 2008
what is surprising is that I have here an Ubuntu box with proj 4.6.0
package and a mapserver 5.2.0 compiled on it without any problem.
Jacolin Yves a écrit :
> Hi Guillaume,
> This is a fresh system install from a "virtual private server" under OpenVZ, I
> tried to remove all packetage with apt-get remove, and nothing is removed ;)
> Furthermore I setup the option --with-proj which link to /usr/local/lib where
> libproj is installed (by myself).
> I built all main dependance (proj, gdal, geos, libecw and agg).
> It seems that configure script test pj_transform in proj and if this is not
> present, think it is an old proj release. I ma going to check in the proj ML
> to know more about this.
> Regards,
> Y.
> Le Tuesday 19 August 2008 11:31:36 Guillaume Sueur, vous avez écrit :
>> make sure you don't have any pre-installed Proj lib which would get
>> linked during the ./configure
>>> Hello,
>>> I am trying to build mapserver 5.2.0 with proj-4.6.0. The ./configure
>>> script tells me : "configure: error: This version of PROJ is too old.
>>> PROJ4.4.2 or later is required." , here is the configure comande line:
>>> ./configure
>>> --with-postgis
>>> --with-wmsclient --with-wfsclient
>>> --with-geos
>>> --with-proj=/usr/local/
>>> --with-gdal --with-ogr
>>> --with-freetype=/usr/bin/freetype-config --with-eppl
>>> --with-xpm=/usr/X11R6/lib/ --with-gd=/usr/
>>> --with-agg=/mnt/data/compil/agg-2.5/
>>> --with-curl-config=/usr/bin/curl-config
>>> --with-tiff --with-xml2-config=/usr/bin/xml2-config
>>> Do you know how to resolv this?
>>> Thanks
>>> Y.
