[MAPSERVER-USERS] epsg code for 'UTM 43 North'
Gregor Mosheh
gregor at hostgis.com
Tue Aug 19 13:01:01 EDT 2008
Ritesh Ambastha wrote:
> How can I calculate exact EPSG code for the date projected in 'UTM 43 North'
The UTM codes, the ones I've used anyway, all start with 267 or 269,
then the zone. 267 for NAD27 and 269 for WGS84/NAD83
So I would suspect yours to be 26743 or 26943
You'd want to check PROJ's EPSG file to verify it, though:
/usr/share/proj/epsg
Gregor Mosheh / Greg Allensworth, BS, A+
System Administrator
HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
