[mapserver-users] Using mapserver with EPSG:900913
Subha Ramakrishnan subha at gslab.com
Thu Aug 21 05:11:46 PDT 2008
Could you also check the map file and tell me if i am making a mistake
there?
This is the map file i am using.
MAP
NAME MAP_POINTS
SIZE 725 800
IMAGETYPE PNG
EXTENT 6679169.446666667 -7.081154550627918 11131949.077777777
4865942.278825832
WEB
METADATA
   wms_srs "EPSG:4326 EPSG:900913"
END
END
PROJECTION
"init=epsg:900913"
END
LAYER
CONNECTIONTYPE postgis
NAME indiastates
CONNECTION "user=postgres dbname=test host=localhost"
TYPE POINT
STATUS DEFAULT
#DATA "topology from states"
DATA "topology from india_states using unique id using SRID -1"
CLASS
   COLOR 255 0 0
END
END
END
Is it possible for you to share your map file if you have any?
Regards,
Subha
Rafael Almeida Fernandez Soto wrote:
> Subha..
> You need to insert a EPSG:900913 description code in PROJ4 config
> files and a row in spatial_ref_sys table in postgis DB. By default
> PROJ4 has not a 900013 projection reference.
> Try it!
> Best regards
> Rafael Soto
> 2008/8/20 Subha Ramakrishnan <subha at gslab.com <mailto:subha at gslab.com>>
>     Hi :
>     We are building a map based web portal using openlayers ,UMN
>     mapserver[5.0.2] and postgis DB.We use google as the base map
>     through openlayers.We need to overlay our custom layers from the
>     db on top of this base map, for that we are using Mapserver (is
>     run on a FC7 linux machine). It is observed that by default
>     openlayers converts google projection [900913] to EPSG:4326 when
>     the base map is fetched.
>     Now when we try to overlay an image that the mapserver generates,
>     there is a mismatch on the base map, though mapserver uses
>     epsg::4326. After searching over the internet theere seems to be
>     only one solution which is displaying the base map itself in
>     epsg:900913 and emit the mapserver image also in the same
>     projection. The problem is we are not able to generate an image
>     through mapserver in epsg::900913.
>     We have taken following measures untill now :
>     1> For using epsg:900913 projection in mapserver, we have added
>     following entry in the /usr/local/share/proj/epsg file.[proj
>     version 4.6]
>      "<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
>     +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs <>"  2>
>     We have added following entry in the "in the spatial_ref_sys table
>     in postgis DB.
>     "900913 ,'EPSG',900913,'GEOGCS["WGS 84", DATUM["World Geodetic
>     System 1984", SPHEROID["WGS 84", 6378137.0,
>     298.257223563,AUTHORITY["EPSG","7030"]],
>     AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich", 0.0,
>     AUTHORITY["EPSG","8901"]], UNIT["degree",0.017453292519943295],
>     AXIS["Longitude", EAST], AXIS["Latitude",
>     NORTH],AUTHORITY["EPSG","4326"]],
>     PROJECTION["Mercator_1SP"],PARAMETER["semi_minor", 6378137.0],
>     PARAMETER["latitude_of_origin",0.0], PARAMETER["central_meridian",
>     0.0], PARAMETER["scale_factor",1.0], PARAMETER["false_easting",
>     0.0], PARAMETER["false_northing", 0.0],UNIT["m", 1.0], AXIS["x",
>     EAST], AXIS["y", NORTH],AUTHORITY["EPSG","900913"]] |','+proj=merc
>     +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
>     +k=1.0 +units=m +nadgrids=@null +no_defs');  The mapfile is as
>     follows: (With this, We get a blank image without any exception.)
>     MAP
>     NAME MAP_POINTS
>     SIZE 725 800
>     IMAGETYPE PNG
>     4865942.278825832
>     WEB
>     METADATA
>     END
>     END
>     PROJECTION
>     "init=epsg:900913"
>     END
>     LAYER
>     NAME indiastates
>     TYPE POINT
>     STATUS DEFAULT
>     CLASS
>        COLOR 255 0 0
>     END
>     END
>     END
>     The client (openlayer) code is as follows :
>             options = {
>                 projection: new OpenLayers.Projection("EPSG:900913"),
>                 displayProjection: new OpenLayers.Projection("EPSG:4326"),
>                 units: "m",
>                 maxResolution: 156543.0339,
>                 maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
>                                                  20037508, 20037508.34)
>              map = new OpenLayers.Map('map', options);
>              var gphy = new OpenLayers.Layer.Google("Google
>     Physical",{type: G_PHYSICAL_MAP,'sphericalMercator': true});
>           map.addLayers(gphy);
>             var lonLat = new OpenLayers.LonLat(82, 23) ;
>     lonLat.transform(map.displayProjection,map.getProjectionObject());
>            map.setCenter(lonLat,5);
>              var wms ;
>            wms = new OpenLayers.Layer.WMS( layername,
>           "http://localhost/cgi-bin/mapserv?",
>           { map: 'demo.map',
>             projection:"EPSG:900913",
>             transparent: 'true', layers: 'indiastates',
>             format: 'image/png'},{singleTile: 'true'} );
>                map.addLayer(twms1);
>     Can anyone help us in any way?
>     Also,
>             We have tried overlaying layer fetched from our map server
>     on different basemaps from (meta carta and tera pages) and have
>     found it overlays perfectly  So clearly there is is problem
>     overlaying on google map through openlayers in epsg : 4326.
>     Thanks and sorry for the long mail.
>     Expecting a reply.
>     Subha.
>     _______________________________________________
>     mapserver-users mailing list
>     mapserver-users at lists.osgeo.org
>     <mailto:mapserver-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapserver-users
> RAFAEL Almeida Fernandez Soto :: rafael at opengeo.com.br
> <mailto:rafael at opengeo.com.br>
> Consultant in FOSS GIS :: 55 21 2518-6233 :: 55 71 8802-0600
> OpenGEO :: On-demand training and solutions :: www.opengeo.com.br
> <http://www.opengeo.com.br>
> GEO Livre community:: Because Geoinformation should be free ::
> www.geolivre.org.br <http://www.geolivre.org.br>
> Be free by using Free Software, such as MapServer, PostgreSQL/PostGIS,
> gvSIG...
> This message has been scanned for viruses and
> dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
> believed to be clean.
More information about the MapServer-users mailing list
