[mapserver-users] Apache can't start on windows
bartvde at osgis.nl
bartvde at osgis.nl
Tue Aug 26 07:01:08 EDT 2008
Possibly the Microsoft Runtime is not available on your system, see also
the following thread:
http://www.nabble.com/fastCgiServer-with-ms4w-td18348539.html
You can also just comment the following line in httpd.conf if you don't
need FastCGI:
#LoadModule fcgid_module modules/mod_fcgid.so
Best regards,
Bart
> Hi,
> I have installed mapserver5.2 (Ms4W) on windows xp. but i can't get
> started
> the apache. i have tried with port 80,8080. but it is the same. it display
> on the system event the following messages
> The Apache MS4W Web Server service terminated with service-specific error
> 1
> (0x1).
> The Apache MS4W Web Server service entered the stopped state. --info
> The Apache MS4W Web Server service was successfully sent a start
> control.--info
> Generate Activation Context failed for C:\Program
> Files\ms4w\Apache\modules\mod_fcgid.so. Reference error message: The
> operation completed successfully.
> Resolve Partial Assembly failed for Microsoft.VC90.CRT. Reference error
> message: The referenced assembly is not installed on your system.
> Dependent Assembly Microsoft.VC90.CRT could not be found and Last Error
> was
> pls pls , say something to these errors.
> thanks
> Helen
> http://n2.nabble.com/Apache-can%27t-start-on-windows-tp783741p783741.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
