[mapserver-users] Apache can't start on windows
helen
ahelen19 at gmail.com
Wed Aug 27 02:42:49 EDT 2008
Thanks for ur help i get it working. The problem was i have to start the
apache from the command line.
i think it should be told that apache can be started only from the command
line.
thanks
Helen
Jeff McKenna wrote:
> This is issue was first reported on August 14th
> (http://www.nabble.com/apache-does-not-start-(ms4w-Apache-conf-httpd.conf)-td18977162.html)
> and to fix it you need to comment the line that Bart mentioned and
> restart Apache. Another option is that you uninstall MS4W and go back
> to the downloads page and re-download it, since this issue was fixed on
> the 14th. Hint: always use the commandline to restart Apache
> (/ms4w/restart-apache.bat) so you can see the messages that Apache
> reports, otherwise you will get a "black screen" that flashes quickly
> when you click on it directly.
> Also, please note that MS4W does have its own mailing list for reporting
> issues such as these (join at:
> http://lists.maptools.org/mailman/listinfo/ms4w-users).
> thanks.
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> helen wrote:
>> thanks for the fast response. i have tried to install the c++ runtime
>> (vcredist_x86.exe) but black screen comes and nothing appeared. i comment
>> the fcgid_module but the result is the same. please help me
>> thanks in advance
>> Helen
>> bartvde wrote:
>>> Possibly the Microsoft Runtime is not available on your system, see also
>>> the following thread:
>>> http://www.nabble.com/fastCgiServer-with-ms4w-td18348539.html
>>> You can also just comment the following line in httpd.conf if you don't
>>> need FastCGI:
>>> #LoadModule fcgid_module modules/mod_fcgid.so
>>> Best regards,
>>> Bart
>>>> Hi,
>>>> I have installed mapserver5.2 (Ms4W) on windows xp. but i can't get
>>>> started
>>>> the apache. i have tried with port 80,8080. but it is the same. it
>>>> display
>>>> on the system event the following messages
>>>> The Apache MS4W Web Server service terminated with service-specific
>>>> error
>>>> 1
>>>> (0x1).
>>>> The Apache MS4W Web Server service entered the stopped state. --info
>>>> The Apache MS4W Web Server service was successfully sent a start
>>>> control.--info
>>>> Generate Activation Context failed for C:\Program
>>>> Files\ms4w\Apache\modules\mod_fcgid.so. Reference error message: The
>>>> operation completed successfully.
>>>> Resolve Partial Assembly failed for Microsoft.VC90.CRT. Reference error
>>>> message: The referenced assembly is not installed on your system.
>>>> Dependent Assembly Microsoft.VC90.CRT could not be found and Last Error
>>>> was
>>>> pls pls , say something to these errors.
>>>> thanks
>>>> Helen
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Apache-can%27t-start-on-windows-tp783741p786208.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
