[mapserver-users] show only some point on the map
valerio vianello
valerio.vianello at yahoo.it
Thu Aug 28 01:28:55 PDT 2008
Dear Till,
Thanks for the suggestion.
But with variable substitution I am able to specify only one parameter like
EXPRESSION ([FNR]=%myid%)
in this case on the map will be shown only one point (if myid is unique) or a group of points (if myid is shared among them)
in my case I want show the points with myid1,myid2,myid3...
how I should set this into the mapfile ?
regards
Valerio
--- Gio 28/8/08, Till Adams <adams at terrestris.de> ha scritto:
Da: Till Adams <adams at terrestris.de>
Oggetto: Re: [mapserver-users] show only some point on the map
A: valerio.vianello at yahoo.it
Cc: "mapserver" <mapserver-users at lists.osgeo.org>
Data: Giovedì 28 agosto 2008, 09:35
Dear Valerio,
I guess what you need is this:
http://mapserver.gis.umn.edu/docs/reference/mapfile/variable_sub
So add a variable substitution and insert it into your expression in the
CALL section of your layer.
Regards, Till
> Dear list,
> I have this question:
> I have a map file in which there is a POINT layer that uses a
> shapefile as datasource. Is possible with mapserver to do a request to
> show only some point on the map ?
> I know that i can show a group of points or only one point using
> FILTER and CLASSITEM into the map file but my goal is a bit different.
> In my case each poi has an ID into the shapefile, and I want make a
> request to serve the follow question:
> Show on map the poi with ID 3,6,8.
> any suggetsion ?
> P.S I'm using CGI interface maybe is this possible to do with
mapscript ?
> thanks everybady
> Valerio
> __________________________________________________
> Do You Yahoo!?
> Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da
> tanto spazio gratuito per i tuoi file e i messaggi
> http://mail.yahoo.it
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
Do You Yahoo!?
Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da tanto spazio gratuito per i tuoi file e i messaggi
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080828/ebd1a222/attachment.htm>
More information about the MapServer-users
