[mapserver-users] grayscale images using classgroups
Martin Kofahl
M.Kofahl at gmx.net
Mon Dec 1 00:26:32 EST 2008
I found a formula RGB2grayscale = 0.299R + 0.587G + 0.114B and would like to apply this on a class section in order to use the STYLE-parameter for serving a raster layer colored or generic grayscaled. Due to processing instructions work on layer level only, they do not help in this case. I'm looking for a solution like this:
CLASS
CLASSGROUP 'grayscale'
STYLE
COLOR [grayscale] [grayscale] [grayscale]
END
END
CLASS
CLASSGROUP 'color'
STYLE
COLOR [red] [green] [blue]
END
END
-------- Original-Nachricht --------
> Datum: Wed, 26 Nov 2008 09:26:04 -0500
> Von: Yewondwossen Assefa <yassefa at dmsolutions.ca>
> An: Martin Kofahl <M.Kofahl at gmx.net>
> Betreff: Re: [mapserver-users] grayscale images using classgroups
> Martin,
> Are you talking of non-8 bits rasters? Looking into the doc I think
> all the processing directives described there that allows
> classifications on a non 8bit rasters apply at the layer level.
> (http://mapserver.gis.umn.edu/docs/howto/raster_data/#special-processing-directives)
> Best Regards
> Martin Kofahl wrote:
> > Hi,
> > is there an option in the class section of the map file (so it can use
> the style parameter) making the output grayscaled?
> > Martin
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
