[mapserver-users] I need ur help (plz urgent)
Amiya Patra
amiyapatra188 at gmail.com
Tue Dec 2 01:29:33 EST 2008
Hello..
I am new to Mapserver. I have some raster files(tiff). I cant place the
symbol within the created image. But legend is created. Somewhere I read
that raster layer does not support Symbol. And also [map] tag is not working
within HTML template. Error message is msEvalRegex(): Regular expression
error. String ([map]) failed expression test. .I got that SAVEMAP must be
switched on..But how ? I tried to send it via HTML hidden field but I did
not get.
Also if I write PROCESSING "BANDs=1 2 3" then error message is like
msDrawMap(): Image handling error. Failed to draw layer named 'modis'.
drawGDAL(): Unable to access file. Attempt to classify 24bit image, this is
unsupported. I got that by default output image is 8 bit. So I tried to
delare Imagetype JPEG and also Proceesing dither =yes and also via output
object .But ?? If I commented that line then image quality is very very bad.
And also I need MYSQL connection with raster file notes.
Please I need ur help........And I hope I will get response very soon......
Thank you.
MAP
IMAGETYPE JPEG
EXTENT 0.0 0.0 583.0 421.0 # -179.133392 17.674692 179.788208
71.398048 # # 0.004349 0.006191 312.987904 377.680442
SIZE 583 421
SHAPEPATH "/home/nms/MapServerData/data/"
IMAGECOLOR 255 255 255
STATUS ON
TRANSPARENT ON
SYMBOLSET "/home/nms/MapServerData/symbol/symbol.sym"
WEB
TEMPLATE "/home/nms/MapServerData/data/temp1.html"
IMAGEPATH "/home/nms/MapServerData/img/"
IMAGEURL "/img/"
LOG "/home/nms/MapServerData/logs/mapserver.log"
END
LEGEND
KEYSIZE 12 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS METERS
INTERVALS 2
# TRANSPARENT FALSE
STATUS ON
END # Scalebar object ends
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # MODIS raster layer begins here
NAME modis
CLASS
NAME 'I AM ICON'
#KEYIMAGE "/home/nms/MapServerData/data/z.png" #z.gif'
SYMBOL '/home/nms/MapServerData/data/z.gif'
#SYMBOL 'd'
END
# DATA "statesp020"
DATA "DRDO.png"
STATUS OFF
TYPE RASTER
PROCESSING "DITHER=YES"
# PROCESSING "SCALE_1=409,1203"
# PROCESSING "SCALE_2=203,296"
# PROCESSING "SCALE_3=339,1004"
# PROCESSING "SCALE=AUTO"
#TILEINDEX DRDO.shp
#TILEITEM Location
TRANSPARENCY ALPHA
CONNECTIONTYPE OGR
CONNECTION "DRDO.ovf"
PROCESSING "BANDS=1 2 3"
# OFFSITE 255 255 255
JOIN
NAME "test"
TABLE "DRDO.dbf"
FROM "ipForwarding"
TO "LOCATION"
TYPE ONE-TO-ONE
END
METADATA
"t" "x"
END
# CLASSITEM "[pixel]"
# class using simple string comparison, equivelent to ([pixel])
CLASS
NAME "CCC"
TEXT "CCCC"
EXPRESSION "0"
STYLE
COLOR 0 0 0
END
END
# class using an EXPRESSION using only [pixel].
CLASS
NAME "AAA"
EXPRESSION ([pixel] >= x+64 AND [pixel] < 128)
STYLE
COLOR 255 0 0
END
END
# class using the red/green/blue values from the palette
CLASS
NAME "near white"
EXPRESSION ([red] > 200 AND [green] > 200 AND [blue] > 200)
STYLE
# SYMBOL 1
COLOR 0 255 0
END
END
# Class using a regular expression to capture only pixel values ending
in 1
CLASS
NAME "BBB"
EXPRESSION /*1/
STYLE
COLOR 0 0 255
END
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # All map files must come to an end just as all other things must come
to...
<html>
<head>
<title>MapServer Workshop</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link type="text/css" rel="stylesheet" />
</head>
<body bgcolor="#FFFFFF" text="#000000">
<!-- START OF MAPSERVER FORM -->
<form name="mapserv" method="GET" action="/cgi-bin/mapserv">
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="imgext" value="0.0 0.0 583.0 421.0">
<input type="hidden" name="layer" value="modis">
<input type="hidden" name="imgxy" value="290 210">
<input type="hidden" name="mode" value="browse">
<input type="hidden" name="ICON" value="modis,0">
<input type="hidden" name="savemap" value="true">
<!-- FORM SUBMIT BUTTON -->
<div align="center">
<input type="submit" name="submit" value="Refresh">
</div>
<!-- ZOOM/PAN CONTROLS -->
<div align="center">Map Control: <br>
<select name="zoom">
<option value="4" [zoom_4_select]>Zoom In 4x</option>
<option value="3" [zoom_3_select]>Zoom In 3x</option>
<option value="2" [zoom_2_select]>Zoom In 2x</option>
<option value="1" [zoom_1_select]>Recenter</option>
<option value="-2" [zoom_-2_select]>Zoom Out 2x</option>
<option value="-3" [zoom_-3_select]>Zoom Out 3x</option>
<option value="-4" [zoom_-4_select]>Zoom Out 4x</option>
</select>
</div>
<!-- REFERENCE AND LEGEND COLUMN -->
<p>Legend:<br> <img name="legend" src="[legend]"></p>
<!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
<input type="image" name="img" src="[img]"/>
<img src="[scalebar]">
</form>
</body>
</html>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081202/781e3525/attachment-0001.html
