[mapserver-users] Difference in appearance between "mode=map"
andWMS
Roger André
randre at gmail.com
Mon Dec 8 17:51:01 EST 2008
Perfect, yes. That should do exactly what I need. I'd forgotten about
those OWSRequests. Tilecache uses those in its MapServerLayer requests as
well.
Thanks very much Tom
On Mon, Dec 8, 2008 at 2:33 PM, Kralidis,Tom [Ontario] <
Tom.Kralidis at ec.gc.ca> wrote:
> Roger: you can use MapScript WxS
> http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript as an approach to
> run a WMS request via mapscript. Maybe that can work for you?
> ..Tom
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org on behalf of Roger André
> Sent: Mon 08-Dec-08 16:21
> To: Julien-Samuel Lacroix
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Difference in appearance between "mode=map"
> andWMS
> Hi Julien,
> That makes sense, but it doesn't work. I modified my mapfile so that I now
> generate a 20_deg x 20_deg tile that is 600_pixels x 600_pixels. If I
> georeference that image using the extents, I still get incorrect placement.
> Maybe if I choose an output projection which always has square pixels, like
> spherical mercator (?) this will work. I'll give it a shot.
> Is there any way to give a WMS request via mapscript and NOT go through
> CGI?
> Roger
> On Mon, Dec 8, 2008 at 12:25 PM, Julien-Samuel Lacroix <
> jlacroix at mapgears.com> wrote:
> > Hi,
> > I guess would be that the WMS use non-square pixels. So if your BBOX x/y
> > (rectangle in your case) doesn't match you WIDTH/HEIGHT ratio (square in
> > your case) the map will appear stretched. MapServer will actually stretch
> > the map to fit the extent in the WIDTH/HEIGHT.
> > The mode=map don't do that. If your extent doesn't have the same ratio,
> it
> > adds some degree in your extent to fit the size.
> > Make sure your BBOX and EXTENT are a square in your requests and retry
> > Julien
> > Roger André wrote:
> >> Hi All,
> >> I think I'm having an instance of cranial flatulation, but maybe not.
> >> Hopefully you can set me straight.
> >> I need to create an image with Mapserver using mapscript that I can then
> >> georeference manually and use in another application. It needs to look
> >> exactly the same as the image I can already generate via a WMS call that
> >> looks like this:
> >> http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/hydro/hydro.map
> >> &SERVICE=WMS
> >> &version=%221.1.1%22
> >> &REQUEST=GetMap
> >> &LAYERS=imagery
> >> &STYLES=&BBOX=-125,39,-108,54
> >> &WIDTH=600
> >> &HEIGHT=600
> >> &FORMAT=png
> >> &SRS=epsg:4326
> >> I'm testing my mapscript parameters using a simple "mode=map" call to
> >> Mapserver, and the results I'm getting so far don't match the appearance
> of
> >> the WMS output at all. My mapfile has the following extent and
> projection
> >> info in it:
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> EXTENT -125.0 39.0 -108.0 54.0
> >> SIZE 600 600
> >> In addition to the mapfile projection specification, I am also
> specifying
> >> the same projection info in each of my LAYERS as well.
> >> Is it possible to do what I'm trying to accomplish here?
> >> Thanks,
> >> Roger
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Mapgears
> > http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081208/dc698732/attachment.html
