[mapserver-users] Labels with SDE data
Howard Butler
hobu.inc at gmail.com
Tue Dec 9 16:30:39 EST 2008
On Dec 9, 2008, at 3:09 PM, Bistrais, Bob wrote:
> I am using ESRI SDE layers in a Map file. On some polygon layers, a
> text label appears as a strange symbol, such as horizontal lines or
> a square. If I convert the same layer to shapefile and use it as a
> source, the polygon labels look correct.
> How can I correct this so the labels look correct using SDE layers?
The column you are labeling with likely has unicode characters in it
and there is a bug in the MapServer SDE code. See this thread for
some more detail. http://lists.osgeo.org/pipermail/mapserver-users/2008-November/058674.html
Howard
