[mapserver-users] Labels with SDE data
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Dec 9 16:33:14 EST 2008
Thanks Howard. Has anyone ever been able to find a workaround (besides
using shapefiles)?
-----Original Message-----
Sent: Tuesday, December 09, 2008 4:31 PM
To: Bistrais, Bob
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Labels with SDE data
On Dec 9, 2008, at 3:09 PM, Bistrais, Bob wrote:
> I am using ESRI SDE layers in a Map file. On some polygon layers, a
> text label appears as a strange symbol, such as horizontal lines or a
> square. If I convert the same layer to shapefile and use it as a
> source, the polygon labels look correct.
> How can I correct this so the labels look correct using SDE layers?
The column you are labeling with likely has unicode characters in it
and there is a bug in the MapServer SDE code. See this thread for
some more detail.
http://lists.osgeo.org/pipermail/mapserver-users/2008-November/058674.ht
ml
Howard
