[mapserver-users] displaying line starting and ending points
José María Michia
jose.maria.michia at gmail.com
Wed Dec 10 09:44:00 EST 2008
Hello,
2008/12/10 Raivo Alla <snaperski at gmail.com>:
> Hello,
> I have a question concerning how to draw starting and ending points of
> line features.
> One option is to create a separate points layer in ArcGIS, where all
> the starting and ending points of lines are in.
> But is' t there some better solution or workaround how to get things done ?
Using "Postgis" as data store, let you get the start and end points
from line geometry with something like:
DATA "geom from (SELECT oid,StartPoint(the_geom) FROM line_layer) as
foo using unique oid using SRID=-1"
And for end points:
DATA "geom from (SELECT oid,EndPoint(the_geom) FROM line_layer) as foo
See:
http://postgis.refractions.net/documentation/manual-1.3/ch06.html#id2572496
I do not know ArcGIS. Maybe there is something similar to this.
Saludos
José María
> Humbly yours,
> Raivo
> mapserver-users at lists.osgeo.org
