[mapserver-users] Labels with SDE data
Neil Fincham
neil at asdf.co.nz
Thu Dec 11 22:14:46 EST 2008
Hi All,
Frustrating problem I know. I eventually fixed it as below;-
<snip>
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Language_suppo
rt_in_the_geodatabase
You need to set UNICODE_STRING "FALSE" using sdedbtune, then when you
load your data it will be just plain old text that mapserver does not have a
problem with.
</snip>
Remember to do the stddbtune _before_ you load your data though, if it is
already loaded pump it out to shapefiles, sdedbtune and then reload is fine.
Neil
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Wednesday, 10 December 2008 10:09 a.m.
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Labels with SDE data
I am using ESRI SDE layers in a Map file. On some polygon layers, a text
label appears as a strange symbol, such as horizontal lines or a square. If
I convert the same layer to shapefile and use it as a source, the polygon
labels look correct.
How can I correct this so the labels look correct using SDE layers?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081212/1e45c1b1/attachment.html
