[mapserver-users] wfs data conversion with ogr2ogr?
Knut Behrends
knb at gfz-potsdam.de
Mon Dec 15 03:33:42 EST 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all,
I have received data from a WFS that was returned in this format:
(Sample feature member)
<gml:featureMember>
<featureSet_704 fid="featureSet_704-feature_1732">
<gml:boundedBy>
<gml:Box>
<gml:coord>
<gml:X>4436682.0</gml:X>
<gml:Y>5783076.0</gml:Y>
</gml:coord>
<gml:coord>
<gml:X>4441086.0</gml:X>
<gml:Y>5786776.0</gml:Y>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<GEOM_ID>1732</GEOM_ID>
<NAME>Marienborn</NAME>
</featureSet_704>
</gml:featureMember>
ogrinfo can parse the file:
ogrinfo SA_PLACES.gml
Had to open data source read-only.
INFO: Open of `SA_PLACES.gml'
using driver `GML' successful.
1: featureSet_704
ogr2ogr can also convert the file to, say, Esri Shapefile. There isI
must assign a source SRS and a target SRS and force a source geometry type.
INFO: Open of `out/featureSet_704.shp'
using driver `ESRI Shapefile' successful.
Layer name: featureSet_704
Geometry: Line String
Feature Count: 100
Extent: (0.000000, 0.000000) - (0.000000, 0.000000)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]]
GEOM_ID: Real (11.0)
OGRFeature(featureSet_704):0
GEOM_ID (Real) = 1732
NAME (String) = Marienborn
After successful conversion, however, only the GEOM_ID and the NAME are
exported. The spatial information is ignored lost during the conversion.
Maybe it's in the wrong format, but it is obviously present in the GML
fragment above. What can I do to convert the spatial information that is
contained in the <X> and <Y> elements?
Knut
____________________________________________________________________________
Knut Behrends Phone: +49 (0) 331 288 1688
Potsdam 14473 KeyID: 0xF22CACEF (PGP Public Key)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAklGFmYACgkQcfWHNfIsrO9NNACfTwBojDKZ0MU3J/yVUBiof5JP
P28AnRStqwySPcQ9gM+hjAgQBNZYRZz4
=Eane
-----END PGP SIGNATURE-----
