[mapserver-users] problem using some fonts on pdf output
José María Michia
jose.maria.michia at gmail.com
Mon Dec 15 14:34:58 EST 2008
I've found that option "ANGLE=follow" not works with PDF output format.
I guess it might be useful to send a message to where they are
planning changes to the PDF support:
>> And I see there's support for an alternate PDF library planned:
>> http://trac.osgeo.org/mapserver/ticket/2661
So, i will to do this.
Saludos
José María
2008/12/15 José María Michia <jose.maria.michia at gmail.com>:
> 2008/12/15 Brent Fraser <bfraser at geoanalytic.com>:
>> José,
>> I did some investigation and I think I found the line in mappdf.c that
>> needs to be changed, line 1318:
>> /*load font using alias*/
>> // font = PDF_load_font(pdf, "f1" ,0 ,"winansi", NULL
>> font = PDF_load_font(pdf, label->font ,0 ,"winansi", "embedding=true" );//
>> changed so (multiple) fonts are embedded
>> It appears to work on my XP computer, but I don't have a linux box to test
>> on. So if someone could test on linux etc, I'd appreciate it.
> I tried this on my Linux, and works well.
> Note: if the font who used, have license restrictions, the font can
> not be embedded.
>> Brent Fraser
> Thanks very much Brent. Now, I will to use "Times" where I desired.
> Something strange (to me) with this: I have not had a problem to use
> "Italic Times" in the first case where I could not use Times.
> In the file "FONTSET," I have defined:
> times /fontpath/times.ttf
> timesi /fontpath/timesi.ttf
> Before modify the code with the changes proposed by Brent, "times" was
> substituted for "Sans", but "timesi" remained "Times Italic" (in the
> PDF file).
> Saludos
> José María
>> José María Michia wrote:
>>> 2008/12/12 Brent Fraser <bfraser at geoanalytic.com>:
>>>> José,
>>>> I think it has to do with font embedding in the output pdf. Looking at
>>>> the
>>>> source code, Mapserver appears to embed fonts used for symbols, but not
>>>> for
>>>> text labels.
>>>> Brent Fraser
>>> I've tried use the font Times as symbol, and yes, font are embedded in
>>> the resultant pdf. But, the labels using the same font in this file,
>>> not uses the same font. This is only a test, is not a good solution,
>>> because forcing to use the desired font as symbol.
>>> Maybe is easy to change the code for include in the PDF the fonts used
>>> in labels, but not for me right now. I hope to learn how some day.
>>> Thanks to Brent and all the people of MapServer.
>>> Saludos
>>> José María
>>>>> Hi all.
>>>>> I have a mapfile, with some layers, with labels. I wish to use two
>>>>> differents fonts, "arial" and "times". I have the two fonts as tff.
>>>>> All work fine when I use shp2img utility program for make PNG files.
>>>>> But, when I change output format to PDF, the text that must be in
>>>>> times font, appears in other font (a Sans variant). I've opened the
>>>>> PDF in Acroread and Inkscape, with same results.
>>>>> I'm using:
>>>>> Linux Gentoo
>>>>> Mapserver 5.2.1 from sources
>>>>> "Sans" is nice font, and I happy with the map produced, but I wish to
>>>>> know what happens. (I need "PDF files", and not "PNG files", because
>>>>> the final maps are hardcopy maps).
>>>>> Thanks for any advice.
>>>>> Saludos
>>>>> José María
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
