[mapserver-users] msTileSetup(): CGI error. Tile API is not	available.
    Christopher Schmidt
    crschmidt at metacarta.com
    Mon Dec 15 14:46:05 PST 2008
On Mon, Dec 15, 2008 at 05:24:39PM -0500, Chad Clabaugh wrote:
> Hello,
> I'm creating my first map server and I'm trying to generate tiles for gmap
> from shapfiles.  I have successfully gotten the mapserver to render the
> shapefiles using the following url:
> http://000.000.000.000/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverag
> e.map
> <http://000.000.000.000/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/covera
> ge.map&mode=map> &mode=map
> but when I try to use (only "mode" changes):
In order to use the Tile API, you must have proj support. Is your
MapServer compiled with PROJ support?
You can check this with:
mapserv -v
and looking for SUPPORTS=PROJ.
-- Chris
> e.map
> ge.map&mode=tile> &mode=tile
> I receive the error:
> I know that I'll need more url switches (I've simplified for the example),
> however, I cannot find anything online concerning this error.  I've compiled
> this on SUSE linux, and the map file contains only one simple map and layer
> section.
> If you need more info, please let me know.
> I am also wondering if I'm going about this the correct way.  I would
> ideally like to generate a tile cache rather than generate per request.  But
> I have not found a tutorial to do such (I'm sure there's one out there).
> Thank you much!
> Chad Clabaugh
> Technical Support, Engineering
> Office: 260.760.6398
> Mobile: 260.466.8861
> mapserver-users at lists.osgeo.org
Christopher Schmidt
MetaCarta
More information about the MapServer-users
