[mapserver-users] wfs data conversion with ogr2ogr?
bartvde at osgis.nl
bartvde at osgis.nl
Tue Dec 16 04:58:20 EST 2008
If you look at the XML schema, i.e.
http://geoportal.geodaten.sachsen-anhalt.de/geodatenportal/servlet/gtEntryPoint?&REQUEST=DescribeFeatureType&VERSION=1.0.0&SERVICE=WFS&TYPENAME=featureSet_704
the optional field VERWALTUNG should contain the geometry.
Apparently these are not filled in the dataset that the WFS uses.
So you are doing nothing wrong, and I think you should contact the
maintainer of the WFS to ask if VERWALTUNG is present in any feature or
that it is always non-existant.
Best regards,
Bart
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Frank Warmerdam schrieb:
>>> Hash: SHA1
>>> Hi all,
>>> I have received data from a WFS that was returned in this format:
>>> (Sample feature member)
>>> <gml:featureMember>
>>> <featureSet_704 fid="featureSet_704-feature_1732">
>>> <gml:boundedBy>
>>> <gml:Box>
>>> <gml:coord>
>>> <gml:X>4436682.0</gml:X>
>>> <gml:Y>5783076.0</gml:Y>
>>> </gml:coord>
>>> <gml:coord>
>>> <gml:X>4441086.0</gml:X>
>>> <gml:Y>5786776.0</gml:Y>
>>> </gml:coord>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> <GEOM_ID>1732</GEOM_ID>
>>> <NAME>Marienborn</NAME>
>>> </featureSet_704>
>>> </gml:featureMember>
>>> After successful conversion, however, only the GEOM_ID and the NAME are
>>> exported. The spatial information is ignored lost during the
>>> conversion.
>>> Maybe it's in the wrong format, but it is obviously present in the GML
>>> fragment above. What can I do to convert the spatial information that
>>> is
>>> contained in the <X> and <Y> elements?
>> Knut,
>> The above feature fragment from a WFS lacks a geometry properly. The
>> boundedBy properly is normally ignored by OGR. Following is a simple
>> example of a GML feature with a point geometry attribute.
>> <gml:featureMember>
>> <airports fid="2">
>> <NAME>Bowstring Municipal Airport</NAME>
>> <LAT> 47.5583</LAT>
>> <LON> -93.8689</LON>
>> <ELEVATION> 1372.0000</ELEVATION>
>> <QUADNAME>Jessie Lake</QUADNAME>
>> <ogr:geometryProperty><gml:Point><gml:coordinates>434634,5267578</gml:coordinates></gml:Point></ogr:geometryProperty>
>> </airports>
>> If you can influence your WFS, then producing something a bit like this
>> might be good.
> The (non-UMN-mapserver based) WFS is public, and I am acting as a WFS
> client, merely retrieving data. Maybe it's just the HTTP GET request
> that was misspelled or incomplete.
> This was my request:
> http://geoportal.geodaten.sachsen-anhalt.de/geodatenportal/servlet/gtEntryPoint?&REQUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=featureSet_704&BBOX=4400161.55779751,5779082.69612775,4502841.70515686,5881251.07072079&MAXFEATURES=100
> Are these the correct URL parameters?
> ____________________________________________________________________________
> Knut Behrends Phone: +49 (0) 331 288 1688
> Potsdam 14473 KeyID: 0xF22CACEF (PGP Public Key)
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iEYEARECAAYFAklHdWYACgkQcfWHNfIsrO80hgCdETv+sJBSTYcLYTj9t76UZwwe
> 1IEAoKAgXrz4RwwDrmsVA6aUPkSgot6L
> =RyzI
> -----END PGP SIGNATURE-----
> mapserver-users at lists.osgeo.org
