[mapserver-users] msTileSetup(): CGI error. Tile API is not
available.
Christopher Schmidt
crschmidt at metacarta.com
Tue Dec 16 09:14:48 EST 2008
On Tue, Dec 16, 2008 at 08:53:50AM -0500, Chad Clabaugh wrote:
> THANKS!
> Ok, it doesn't list it as supported. But when I try to compile using
> ./configure --make-proj and make, it still doesn't list it. Even though it
> seemed to compile correctly and lists PROJ with DUSE.
I'm assuming '--make-proj' was a typo, and you meant '--with-proj'.
Is proj installed in /usr? Or is it perhaps installed in /usr/local, and
you need to point there? The docs suggest, for example:
--with-proj=/usr/local
Good Luck, and Best Regards,
Christopher Schmidt
MetaCarta
