[mapserver-users] Blank image after map request
Fawcett, David
David.Fawcett at state.mn.us
Tue Dec 16 09:55:33 EST 2008
Alexandre,
What URL are you using to request your map?
Are you explicitly requesting your layer 'mosaico' in the URL (e.g. &layers=mosaico)? If not, change the layer status to default for testing purposes.
Try this first before exploring whether you have problems with your extent or spatial reference systems.
Is mosaico.tif georeferenced and does it fall within the extent specified in your map file? Also, is it in the same spatial reference system as the projection stated in your map file?
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of RODIER BATISSE, ALEXANDRE
Sent: Tuesday, December 16, 2008 7:31 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Blank image after map request
Hi everyone,
I am begining with mapserver for windows and i have this problem:
Mapserver work (theorycally) fine, because http://localhost/cgi-bin/mapserv.exe request in web navigator answer "No query information to decode. QUERY_STRING is set, but empty".
I have a .map file in c:\ms4w\Apache\htdocs\map\ directory. (I put it in anex).
But when a try to make a map request mapserver give a blank image (800x500 pixel)
Whyyyyyyy!!!
Thank you for your help.
Alexandre Rodier
Asistencia Técnica del SIGA
Servicio de Información e Integración Ambiental
Dirección General de Patrimonio Natural y Biodiversidad
Consejería de Agricultura y Agua.
c/ Arquitecto Emilio Piñero, 1 Entresuelo C
30.007 Murcia
Tel. 968246272
Correo-e: alexandre.rodier at carm.es <mailto:alexandre.rodier at carm.es>
http://www.carm.es/medioambiente <http://www.carm.es/medioambiente>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081216/eee9aaeb/attachment-0001.html
