[mapserver-users] Re: AGG OUTPUTFORMAT Question
thomas bonfort
thomas.bonfort at gmail.com
Wed Dec 17 15:07:07 EST 2008
just a side note on the subject: seeding your tiles probably involves
using tilecache's metatiles. quantizing a 5x5 tile in mapserver will
very probably give poorer visual results than quantizing each
individual tile. For this reason I tend to seed in 24bit mode, and
postprocess the split up tiles with pngnq:
for file in `find tilecache/mylayer -name "*.png"`;
do
echo $file;
pngnq -e .png.tmp -n 256 $file;
mv $file.tmp $file;
done
On Wed, Dec 17, 2008 at 20:56, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Steve,
> you have the undocumented FORMATOPTION QUANTIZE_NEW=yes that uses the
> median cut quantization algorithm which is slower but much better than
> the GD one. Still no guarantee your tiles will have exactly the same
> colors, although in practice this seems to be the case.
> keep me in touch with your findings, so this can be documented if the
> results are ok.
> cheers,
> thomas
> On Wed, Dec 17, 2008 at 20:38, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi Thomas, et al,
>> I need to generate tiles using AGG output and need them to be 8 bit png
>> images.
>> http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
>> Does not make it clear if any of the formats shown are 8 bit png images and
>> it does not note the use of:
>> FORMATOPTION "PALETTE_FORCE=TRUE"
>> FORMATOPTION "PALETTE=/u/data/maps/palette-agg.txt"
>> What is the proper way to set up OUTPUTFORMAT to use AGG to get the best
>> quality 8 bit output. I think I need to use the PALETTE* options to control
>> color shifts in adjacent tiles.
>> I would be happy to add a comment to the above link with this additional
>> info.
>> Best regards,
>> -Steve W
