[mapserver-users] tileindex without .jgw
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 18 11:20:37 EST 2008
Jochen Wagner wrote:
> Hi,
> I have some airial photos (format is .jpg) without any
> georeference-files (.jgw).
> But there is a shapefile with with the coordinates of the upper left,
> upper right, lower left and lower right coordinates and the rows and
> columns (pixels).
> The aerialphotos are rectangles but the shapes are trapezoidal.
> Is it possible to georeference the files "on the fly" with the
> shapefile in mapserver using an image catalog?
> If I'm using the tileindex, the arialphotos are not at the correct
> position and scaling.
Jo,
No, currently the tileindex is only used to select the right files for
the area of interest. It is still necessary that they have georeferencing
per-file in a form that mapserver (GDAL) can utilize and that does not
include the values from the tile index.
The obvious step is to write a script to produce world files for from the
shapefile. There are some other more complicated options if having the
files without a world file is important to you.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
