[mapserver-users] pdf OUTPUT format for annotation layer not
working
José María Michia
jose.maria.michia at gmail.com
Fri Dec 19 12:04:11 EST 2008
2008/12/19 Brent Fraser <bfraser at geoanalytic.com>:
> José,
> I ran into that problem a couple of days ago. I had a rogue COLOR object
> in my LAYER:
> LAYER
> NAME '082h04_1_0_TO_2520009_0'
> TYPE annotation
> DATA
> 'C:\Inetpub\wwwroot\Topo\data\vector\Canvec_50\082\H\082h04_1_0_TO_2520009_0'
> STATUS DEFAULT
> LABELITEM 'TOPONAME'
> CLASSITEM 'TYPE'
> CLASS
> COLOR 0 0 0 # this causes a "too large for PDF" error
> NAME 'TYPE = 4' EXPRESSION '4' LABEL FONT "tuffy5"
> TYPE TRUETYPE
> COLOR 80 80 80
> Taking out the (useless) COLOR object made it work.
> Brent Fraser
Yes! This solves the problem.
Thanks very much.
José María
> José María Michia wrote:
>> Hi all!
>> I get this error message with "TYPE ANNOTATION" in a polygon layer:
>> $ shp2img -m ubicacion_regional.map -o p.pdf
>> fatal exception: [1906] PDF_moveto: Floating point number 2147483648
>> too large for PDF
>> With "TYPE polygon" the program runs normally.
>> I've tried with MapServer version 5.2.1 and with svn version.
>> Ask me the data and the mapfile, so you can try to reproduce this.
>> I've opened a ticket in trac system, but, maybe someone in the list
>> knows what is wrong with this.
>> Thanks for any advice.
>> Saludos
>> José María
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
