[mapserver-users] RE: Display of polygon in map
Paul Alarcon
paul_pag00 at hotmail.com
Sat Dec 27 08:58:18 EST 2008
Hello friend maybe i know whats the problem did you check if you newgeo column is registered on the geometry_column table, because mapserver look for the field of geometry there and then make the graphic
I hope yopu could solveypour problem with this
Happy Holidays
Date: Fri, 26 Dec 2008 19:24:42 -0800From: ml-user+2851-242421009 at n2.nabble.comTo: paul_pag00 at hotmail.comSubject: Re: Display of polygon in maphere it is..I have tried using gid ,srid etc..n its still not working :( LAYER NAME gps_polygon STATUS on TYPE polygon CONNECTIONTYPE POSTGIS CONNECTION "host=localhost dbname=gps_data user=abc password=xyz port=5432" DATA "newgeom FROM gps_polygon USING UNIQUE gid" LABELCACHE on #LABELITEM 'name' HEADER 'templates/header.html' FOOTER 'templates/footer.html' TOLERANCE 3 STYLE #COLOR 212 192 100 # OUTLINECOLOR 200 100 200 OUTLINECOLOR 0 0 255 END LABEL COLOR 255 0 0 POSITION ul SIZE large END # label END # class END # layer
pag66 wrote:
Hi friend post the connection that you're using maybe it a problem with the select statement, try "the_geom from table using unique gid" if you have and gid field
This email is a reply to your post @ http://n2.nabble.com/Display-of-polygon-in-map-tp1971800p1971802.htmlYou can reply by email or by visting the link above.
_________________________________________________________________
Connect to the next generation of MSN Messenger
http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline
View this message in context: http://n2.nabble.com/Display-of-polygon-in-map-tp1971800p2015902.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081227/94478bc5/attachment.html
