[mapserver-users] Symbol Style Angle Seems Incorrect (MapServer
5.0.2)
David Martin
David at itbeyond.com.au
Sun Dec 28 22:55:12 EST 2008
Using MapServer 5.0.2
I am using a database bind for a SYMBOL Style Angle however I am finding
that the ANGLE show appears to be out and rendering backwards ie: ANGLE
10 is sloping a little to the left not right and angle 350 is sloping to
the right. I am using a symbol made up of a | char as below:
SYMBOL
NAME 'landingground'
TYPE TRUETYPE
CHARACTER "|"
FONT ARIAL
POSITION CC
END
Showing on a map using
CLASS
NAME 'Landing Ground'
EXPRESSION /3/
STYLE
SYMBOL 'circle'
SIZE 10
MAXSIZE 18
MINSIZE 10
COLOR 255 0 0
END
STYLE
SYMBOL 'circle'
SIZE 9
MAXSIZE 17
MINSIZE 9
COLOR 255 255 255
END
STYLE
SYMBOL 'landingground'
SIZE 5
MAXSIZE 12
MINSIZE 5
COLOR 255 0 0
ANGLE [ORIENTATN] # supplied from ShapeFile
ANTIALIAS TRUE
END
END
When I render this URL:
http://mt1.exploroz.com/iMapPlot/GetMapTile.aspx?reload=1&key=test&mode=
map&map_imagetype=png&mapext=13523695.804194272+-3421332.5005978127+1352
6141.78909896+-3418886.5156931253&imgext=13523695.804194272+-3421332.500
5978127+13526141.78909896+-3418886.5156931253&map_size=256+256&imgx=128&
imgy=128&imgxy=256+256
(One of the tiles for my OL system) - showing an Airport defined at
ANGLE 321 you will see the Airstrip sloping to the right when it should
be mirrored and sloping to the left.
Any one else seen this or have a fix?
Regards
David Martin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081229/2a798177/attachment.html
