No subject
Fri Feb 8 15:06:04 EST 2008
Number: Datum: Area: Ellipsoid:
1001 Pulkovo 1942 Germany Krassovsky
You will have to look up the EPSG code for your particular map projection
that uses this datum.
Brent Fraser
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Wednesday, January 26, 2005 2:13 AM
Subject: [UMN_MAPSERVER-USERS] relation between .tab and .map
Does anyone know any web page were indicates the posible values that the
parameters of the coordsys earth projection can have in a .tab file?
parameters of the projection of a .map file can have?
All I want is to put the parameters of the projection from my .tab file to
my .map file, but it doesn't work. For example the "datum" in the corrdsys
earth projection is 1001 but in the map file I do not know what it
corresponds to (NAD27,WG83,...)
Thank you
Jose Luis
