No subject
Fri Feb 8 15:06:04 EST 2008
you might have some experience with this,.
I have found the following PHP extension based on Shapelib C Library
V1.2(reading and writing to shapefiles)
http://cvs.php.net/viewcvs.cgi/pecl/shp/
but i have not been able to get it installed properly on a Windows server.
I am really kind of lost. I though php extentions were . dll files.
Looking at the README from that above link it points to the shapelib files
and one is a .dll ( i DL windows version)
I placed that into my php extension folder and added it to the php.ini,
restarted Apache..
but when i run phpinfo(INFO_MODULES); it does not show up in the listings.
So i guess my question is, Has anyone tried to install this php extension
before on windows when no having map
script installed ?
can this php extension be installed on windows ?
Hope this is not too confusing..
Thanks,
Drew
------=_Part_60798_15068851.1150058536983
Content-Type: text/html; charset=ISO-8859-1
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
Hello,<br><br>I am looking at using a php extension called shaplib on a server that currently <span style="font-weight: bold;">does not</span> have MapServer/MapScript installed.<br><br>From my readings shapelib is installed in map server, so i though some of you might have some experience with this,.
<br><br>I have found the following PHP extension
based on Shapelib C Library V1.2 (reading and writing to shapefiles)<br><br><a href="http://cvs.php.net/viewcvs.cgi/pecl/shp/">http://cvs.php.net/viewcvs.cgi/pecl/shp/</a><br><br>but i have not been able to get it installed properly on a Windows server.
<br><br>I am really kind of lost. I though php extentions were . dll files.<br><div style="margin-left: 40px;">Looking at the README from that above link it points to the shapelib files and one is a .dll ( i DL windows version)
<br><div style="margin-left: 40px;">I placed that into my php extension folder and added it to the php.ini, restarted Apache..<br>but when i run <span style="font-weight: bold;">phpinfo(INFO_MODULES);</span> it does not show up in the listings.
<br><br></div></div>So i guess my question is, Has anyone tried to install this php extension before on windows when no having map <br>script installed ?<br><br>can this php extension be installed on windows ?<br><br>Hope this is not too confusing..
<br>Thanks,<br><br>Drew<br><br>
------=_Part_60798_15068851.1150058536983--
