No subject
Fri Feb 8 15:06:04 EST 2008
snippet at the bottom of Section 4 about gdaltindex and creating a tile
index shapefile. I tried that. =20
Here's what I typed: gdaltindex u_of_ill.shp
~/Desktop/UofImapSquares/*.gif
Here's what was returned to me:
It appears no georeferencing is available for
`/home/jimbo/Desktop/UofImapSquares/A0.gif', skipping.
`/home/jimbo/Desktop/UofImapSquares/A12.gif', skipping.
and so on.........
Ok. Yes. I know. There's no georeferencing info attached.
But, how do I go about attaching georeferencing info? =20
And how do I create, edit, and view a shapefile?
And lastly, do I need a world file to determine a global position for
every tile?
I tried using a text editor Gedit (I figured What the Hey?) to open them
and nope - wasn't in UTF-8 encoding.
I did some digging Google and noticed that you can use ArcView GIS,
ArcMap, ArcGIS, and ArcCatalog to create, edit, and view shapefiles.
I also stumbled across posting that talked about ShapeLib created by
Eduardo Patto Kanegae and maintained by Frank Warmerdam.
I don't have money to spend on buying some GIS program, and ShapeLib
seems like the answer.
Could anyone help?
- Chris
Get news, entertainment and everything you care about at Live.com. Check
it out! <http://www.live.com/getstarted.aspx%20>=20
=20
Explore the seven wonders of the world Learn more!
<http://search.msn.com/results.aspx?q=3D7+wonders+world&mkt=3Den-US&form=3D=
QBR
E>=20
------_=_NextPart_001_01C8006D.BD21A829
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<!--[if !mso]>
<style>
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:blue;
p
{mso-margin-top-alt:auto;
margin-right:0in;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
span.EmailStyle18
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:1963031036;
mso-list-type:hybrid;
mso-list-template-ids:1671702228 -1684646282 67698691 67698693 67698689 =
67698691 67698693 67698689 67698691 67698693;}
@list l0:level1
{mso-level-start-at:0;
mso-level-number-format:bullet;
mso-level-text:-;
mso-level-tab-stop:33.0pt;
mso-level-number-position:left;
margin-left:33.0pt;
text-indent:-.25in;
font-family:Arial;
mso-fareast-font-family:"Times New Roman";}
ol
{margin-bottom:0in;}
ul
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dblue>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Chris =
–<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>OK – it’s not as bad as =
all
that – don’t fire up Photoshop yet. If you have a set =
of
tiles which together create a seamless large image, and those tiles are =
of a
regular size and shape, don’t bother pasting them =
together.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Each world file has six numbers in =
it, two
of which will be 0. For each image tile you need a world file that
contains the X/Y coordinates of the upper left pixel of the image (two =
numbers),
and the dimension (size) of each pixel in X (one number) and Y (one =
number)
units. In the vast majority of cases the last two numbers will be
identical except for sign (the Y value is normally a negative number =
since Y
values decrease as you go from the top to the bottom of the =
image).<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>If your images make a rectangle =
when
pasted together, just treat them as one. Find the X/Y coordinates =
of the
upper left corner of the entire image area, and the X/Y coordinates of =
the
lower right corner of the entire image area. Find the size of the =
entire
mosaiced rectangle in X and Y pixels. The X pixel dimension will =
be (maxx
– minx) / xpixels, and the Y will be (miny – maxy) / =
ypixels.
You should find that the X number is -1 times the Y =
number.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>For all your world files, these two =
X and
Y extent values (the first and fourth lines) will be constants. =
The last
two lines are the upper left X and Y coordinates of each tile. =
Your tiles
will all have the same Y value across each row, and the same X value =
down each
column. You know what the upper-left corner of the upper-left tile =
is,
because you measured it. You know the number of X pixels in each =
tile and
the number of Y pixels in each tile, and you now know the size in X and =
Y units
of each pixel, so you know the extent of each image tile in X and Y =
units, so
you can calculate the upper-left corner coordinate of the image to the =
right
and the image below. Repeat until =
complete.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>All your measurements need to be =
done in
the units of the image’s coordinate system. Is this the =
image you
were asking about earlier that’s in UTM projection? If so, =
you need
UTM coordinates, NOT lat/lon. I wouldn’t recommend Google =
Earth as
a very accurate way to do that, but if it’s close enough for you =
and easy
that’s OK. If you can easily find the corners of your image =
area on
a topo map you can do it on TopoZone and get UTM coordinates accurate to =
within
a few meters just by clicking on the spots that match the corner points =
of your
image.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>If there isn’t an obvious =
landmark
at the corner, you can pick a prominent location NEAR the corner and =
just
measure the number of pixels away from the corner it is. =
It’s just
a bit more bookkeeping but does the same =
thing.<o:p></o:p></span></font></p>
style=3D'font-size:
<p class=3DMsoNormal =
style=3D'margin-left:33.0pt;text-indent:-.25in;mso-list:l0 level1 =
lfo1'><![if !supportLists]><font
style=3D'font-size:10.0pt;font-family:Arial;
color:navy'><span style=3D'mso-list:Ignore'>-<font size=3D1 =
face=3D"Times New Roman"><span
style=3D'font:7.0pt "Times New =
Roman"'>
</span></font></span></span></font><![endif]><font size=3D2 color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>Ed<o:p></o:p></sp=
an></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Ed =
McNierney<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>TopoZone.com<o:p></o:p></span></font=
></p>
style=3D'font-size:
<div>
<div class=3DMsoNormal align=3Dcenter style=3D'text-align:center'><font =
size=3D3
face=3D"Times New Roman"><span style=3D'font-size:12.0pt'>
<hr size=3D2 width=3D"100%" align=3Dcenter tabindex=3D-1>
</span></font></div>
<p class=3DMsoNormal><b><font size=3D2 face=3DTahoma><span =
font-family:Tahoma;font-weight:bold'>From:</span></font></b><font =
size=3D2
face=3DTahoma><span style=3D'font-size:10.0pt;font-family:Tahoma'> UMN =
Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] <b><span =
style=3D'font-weight:
bold'>On Behalf Of </span></b>Christopher Harris<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> Wednesday, =
September 26,
2007 11:15 AM<br>
<b><span style=3D'font-weight:bold'>To:</span></b> =
MAPSERVER-USERS at LISTS.UMN.EDU<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> Re: =
[UMN_MAPSERVER-USERS]
Rasters, TileIndex and Shapefiles - Oh My! Really =
Confused</span></font><o:p></o:p></p>
</div>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>Thanks again, Ed. I need to clear up some =
things that
I guess I didn't make clear.<br>
<br>
I know that a world file provides georeferencing. I meant to say =
that I
had a .gif that had no georeferencing info associated with it, and then =
added
one. From there I got my initial app to work (displaying the big =
map).<br>
<br>
One thing I omitted was that the little .gifs (tiles), when assembled, =
make up
a different big map pic then the one where mentioned =
:<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>“</span></font><font size=3D2
face=3DTahoma><span style=3D'font-size:10.0pt;font-family:Tahoma'>it =
uses one .gif (the
big map pic), attaches the big map to the globe via a world file. =
That
big map .gif had no georeferencing info attached to =
it."<o:p></o:p></span></font></p>
font-family:Tahoma'>Before I had a pic of a large section of a college
campus. Now I have a pic of the entire campus, but in little =
tiles.<o:p></o:p></span></font></p>
font-family:Tahoma'>I know Mapserver makes maps and not pics too. =
I
probably just worded something wrong.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>"So – what do you know =
about
these images? Do you really have a world file that correctly =
describes
your big GIF image? Do you know exactly how the little images were =
created
from the big image? If so, you should be able to figure out how to
generate world files for each individual image. If not, =
you’ll need
to get that information for your big image."<br>
<br>
</span></font><font size=3D2 color=3Dblack face=3DArial><span =
font-family:Arial;color:black'>Yes, I have a world file, but it's for =
the pic
that shows a large section of the campus - not for the big pic that is =
the sum
of the little pics.<br>
<br>
<br>
Ok, so then I have to have a world file for every little tile, but =
before that
I need to correctly set up the world file for the big pic, which I guess =
I'll
need to assemble in Photoshop. Does that sound right? I can =
do it,
it's just a bit tedious lining up the tiles and such. Also, how do =
you
correctly align a pic of some map on the globe. I've been using =
Google
Maps to do it. I'll sit there and study where the pic's corners =
should
approximately be, then get the lat/lon from that (clicking directions to =
or
from will yield the lat/lons).<br>
<br>
Thank you.<br>
<br>
- Chris </span></font><font size=3D2 face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'> =
size=3D2
<hr size=3D2 width=3D"100%" align=3Dcenter>
<p class=3DMsoNormal style=3D'margin-bottom:12.0pt'><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'>Subject: RE: =
Rasters, TileIndex and Shapefiles - Oh My! Really Confused<br>
Date: Wed, 26 Sep 2007 13:36:42 -0400<br>
To: docterrobert at MSN.COM; =
MAPSERVER-USERS at LISTS.UMN.EDU<o:p></o:p></span></font></p>
<div>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Chris –</span></font><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Tahoma'><o:p></o:p></span></font></=
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> </span></font><font size=3D2
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Let me suggest you try to get =
unconfused
just one step at a time!</span></font><font size=3D2 face=3DTahoma><span
p>
style=3D'font-size:
p>
style=3D'font-size:
(the big map pic), attaches the big map to the globe via a world =
file.
That big map .gif had no georeferencing info attached to =
it.”<o:p></o:p></span></font></p>
font-family:Tahoma'> <o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>That’s a bit of a
contradiction. A world file is one way of providing =
georeferencing.
If you’ve got an image “attached” to the Earth via a =
world
file, you’ve georeferenced it.</span></font><font size=3D2 =
face=3DTahoma><span
p>
style=3D'font-size:
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>MapServer makes maps, not =
pictures.
One of the chief differences is that a map has geographic location =
information
associated with it. When you ask MapServer to generate a map for =
you, you
need to tell it the location of the map you want in some coordinate
system. In order for MapServer to know which of your GIF images to =
use in
making the output map, it needs to know the geographic location of each =
of
those images. Otherwise it couldn’t figure out which ones to =
use.</span></font><font
p>
style=3D'font-size:
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>A TILEINDEX is step two in the
process. Once you have a set of more than 1 properly georeferenced =
images
that you’d like to use like a single logical image, you can create =
a
TILEINDEX to do that. But you have to completely and correctly =
make it
through step one first. Once you get the individual images =
properly
georeferenced, gdaltindex will just work.</span></font><font size=3D2
p>
style=3D'font-size:
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>So – what do you know about =
these
images? Do you really have a world file that correctly describes =
your big
GIF image? Do you know exactly how the little images were created =
from
the big image? If so, you should be able to figure out how to =
generate
world files for each individual image. If not, you’ll need =
to get
that information for your big image.</span></font><font size=3D2 =
face=3DTahoma><span
p>
style=3D'font-size:
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>If you do have that world file and =
know
how the tiles were created, let us know (you can post the world file in =
your
reply – it’s just six lines of text).</span></font><font =
size=3D2
p>
style=3D'font-size:
p>
style=3D'margin-left:33.0pt;text-indent:-.25in'><font size=3D2
color:navy'>-</span></font><font size=3D1 color=3Dnavy><span =
style=3D'font-size-adjust: none;
font-stretch: normal'><span =
style=3D'font-size:7.0pt;color:navy'> =
</span></span></font><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Ed</span></font><font size=3D2 =
face=3DTahoma><span
p>
style=3D'font-size:
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Ed McNierney</span></font><font =
size=3D2
p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>TopoZone.com</span></font><font =
size=3D2
p>
style=3D'font-size:
p>
style=3D'font-size:
p>
<div>
size=3D3
size=3D2
September 26,
2007 10:02 AM<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
Confused<o:p></o:p></span></font></p>
</div>
style=3D'font-size:
12.0pt'> </span></font><font size=3D2 face=3DTahoma><span =
style=3D'font-size:
10.0pt;font-family:Tahoma'><o:p></o:p></span></font></p>
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'>Hi. I have a map =
that is
broken up into a bunch of .gif tiles. I want to display them on a =
layer
in Mapserver. I have working version of what I want to accomplish, =
but it
uses one .gif (the big map pic), attaches the big map to the globe via a =
world
file. That big map .gif had no georeferencing info attached to =
it.<br>
<br>
These .gifs have no georeferencing information included or attached as =
well.<br>
<br>
I read Section 4 (and Section 9 too) on the mapserver site page:
http://mapserver.gis.umn.edu/docs/howto/raster_data<br>
<br>
