No subject
Fri Feb 8 15:06:04 EST 2008
- polygon fill color (mapinfo_brush_foreground)
- outlinecolor/line color (mapinfo_pen_color)
- line size (mapinfo_pen_width)
- symbol size (mapinfo_symbol_size)
- label size (mapinfo_text_height)
- label angle (mapinfo_rotation)
- label string (mapinfo_text_string)
- symbol for points (mapinfo_symbol_shape)*
- symbol for lines (mapinfo_pen_pattern)*
- Symbol for polygon fills (mapinfo_brush_pattern)*
* here you have to define corresponding MapServer symbols, the using a
Lookup (ValueMapper) in FME to assign the new values
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC Web-Site: http://www.tydac.ch
TYDAC MapServer: http://www.mapserver.ch
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
From: "Delfos, Jacob" <Jacob.Delfos at MAUNSELL.COM>
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Thu, 11 Oct 2007 07:59:11 +0800
Subject: Re: [UMN_MAPSERVER-USERS] Can I export MapInfo "styleitem" info
to PostGIS?
> Daniel,Flavio,
> Thanks for your replies. At least I know I won't have to bother
> pursuing
> that if it doesn't work.
> I may look into carrying color across. I tried using FME to get style
> across, but I probably did it wrong, because it came out empty.
> I'll look into whether I can write a script to assign colors
> automatically based on an attribute.
> Thanks,
> Jacob
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Daniel
> Morissette
> > Sent: 10 October 2007 21:08
> > "styleitem" info to PostGIS?
> > Flavio Hendry wrote:
> > > Hi Jacob
> > > I do not think that you could do that as the moment. FME
> > (www.safe.com)
> > > would bring the styles along to PostGIS. However there is no way
> to
> > > define any other STYLEITEM as "auto" at the moment.
> > That's correct. The original plan was to eventually support binding
> > STYLEITEM to any attribute which would contain a style string in
> the
> > format that OGR produces/understands, but we never got to
> > that and only
> > STYLEITEM AUTO has been implemented.
> > > "auto" is more or
> > > less limited to colors as far as I know.
> > AUTO also supports mapping symbols, fonts and about anything
> > you find in
> > MapInfo symbology. You need to have the right entries in your
> fontset
> > and symbolset for the mapping to work. This should be covered
> > by the OGR
> > HowTo.
> > > Ideal would be something like
> > > COLORITEM pointing to a column containing RGB color info ...
> > This is possible with v5.0, you'd use:
> > COLOR [mycolor]
> > Where "mycolor" is the attribute name from the data source.
> > Color can be
> > given as a hex value (e.g. #FFFFFF) or an RGB triplet (e.g.
> > 255 255 255).
> > The following properties can accept bindings in 5.0:
> > * Style: angle, color, outlinecolor, size, symbol
> > * Label: angle, color, outlinecolor, size, font, priority
> > That is the reason why LABELITEM, ANGLEITEM, etc were dropped in
> 5.0.
> > e.g. LABELITEM was replaced by "LABEL [mylabelitem]", etc.
> > Daniel
> > Daniel Morissette
> > http://www.mapgears.com/
> This email and any attachments are intended solely for the named
> recipient and are confidential. The copying or distribution of them
> or any information they contain by anyone other than the named
> recipient is prohibited. If you have received this document in error,
> please notify the sender and delete all copies from your computer
> system and destroy all hard copies. It is the recipient's
> responsibility to check this email and any attachments to this email
> for viruses before use.
