Single layer, Multiple colors
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Feb 5 08:56:25 EST 2008
Without and your map file layer text, it is pretty hard to help you with
questions like this.
Also note that like a case statement, the expressions are evaluated in
order. If a record matches the expression in the first class, it will
not be evaluated against the expressions in any of the other classes.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Vishal Nagpal
Sent: Monday, February 04, 2008 10:27 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Single layer, Multiple colors
I have tried multiple class in the same layer but it doesn't work.
Though I am able to use single layer with expression to filter the
values I require.
Thanks,
Regards,
vishal
