join tables question
nelson guda
nelson.guda at GMAIL.COM
Tue Feb 5 16:31:55 EST 2008
Hi all,
I was looking into the JOIN feature. In the reference it says "You
cannot use joins to affect the look of a map." Will there ever be a
way to use a JOIN in this manner? For example, it would be extremely
useful to be able to create maps that use geographic data from an
existing shapefile, modified by parameters from a dynamically created
csv.
I know that you can do something similar fairly easily with postgis,
but I am trying to find ways around postgis since it is so slow and
requires a special server setup.
thanks,
nelson
