mapfile .map syntax for gedit text editor
tim chippy2005 at GMAIL.COM
Wed Feb 6 07:55:24 PST 2008
Whoops! the directories for the files should go in the other way around.
Correct:
mapserver.xml to  /usr/share/mime/packages/
and map.lang to /usr/share/gtksourceview-1.0/language-specs
also for Gutsy, gtksourceview2.0 is a bit different than 1.0
http://live.gnome.org/GtkSourceView
so will see if it can be compatible with that, also.
cheers
tim
More information about the MapServer-users mailing list
