AGG and PNG Output - no white background
thomas bonfort
thomas.bonfort at GMAIL.COM
Thu Feb 7 02:44:19 EST 2008
hi Flavio,
can you double check you're not using quantization or palette_force?
I don't experience the problem you're pointing out if using plain png output.
cheers,
thomas
On Feb 7, 2008 7:56 AM, Flavio Hendry <flavio at tydac.ch> wrote:
> Hi Thomas / Group
> Using PNG Output using AGG, the map background does not turn out white
> (255,255,255) but in some greyish (250,252,250 or similar). Does not
> really matter on screen, but is remarkable printing ... This no matter
> if I use quantize or not. Same map using JPEG no problem.
> Mit freundlichem Gruss / Best Regards
> Flavio Hendry
> TYDAC Web-Site: http://www.tydac.ch
> TYDAC MapServer: http://www.mapserver.ch
> TYDAC SwissMaps: http://www.mapplus.ch
> ############ Mit freundlichen Gruessen / Kind Regards
> ############ mailto:flavio at tydac.ch
> ############ TYDAC AG - http://www.tydac.ch
> #### #### Geographic Information Solutions
> #### #### Luternauweg 12 -- CH-3006 Bern
> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
> Location: http://www.mapplus.ch/adr/bern/luternauweg/12
